Front drivetrain noise - Page 3
This is a discussion on Front drivetrain noise within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Mine is definitely the front gear box in 4x4 the sound changes. Sent from my iPhone using Tapatalk...
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 56
Like Tree8Likes
Thread: Front drivetrain noise
    (SlimRockett) Elite Member SlimRockett's Avatar
    May 2012
    Waxahachie Texas
    118 times
    2017 Ranger Crew 1000 Bronze
    Regular Member Exlawdog's Avatar
    I think I might put the whole thing on blocks and go through the motions to see if I can isolate the noise
    2017 900xp EPS
    Full cab, w/heat and wipers
    All glass W/tip out front
    All camo
    Hydro dump
    Glacier pro w/ hydro
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    Rear LED in bumper lights
    2" Bracket lift
    28" Attack tires
    Air relocate box
    Dragonfire seat belt bypass
    Custom Bed Rack w/led floods and tool holder
    1500# Winch on Bed Rack
    WhoMoto rock sliders
    More to come
    "I may not be the Boss, but I've got a lot of pull"
  3. #23
    2433 times
    Quote Originally Posted by SlimRockett View Post
    That would be correct, Why?
    Because now you have powered the Armature, creating resistance on the Armature plate, in effect tightening up the assembly. (Very Short version)
    It can be corrected, it just requires a little work.
    The straight cut gears will always make some noise, that is inherent to the design.
    Toxic-21 Motorsports.
    It Costs a lot of Money to look Cool!
    May 2012
    Waxahachie Texas
    118 times
    My cousins 14' 570 does the same thing we took it apart I didn't see any way to tighten it.
  6. #25
    Probably. It's all free from the dealer, so I will let them do the process of elimination.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
  7. #26
    Good news. The new prop shaft did the trick. No vibration or rattle anymore.
    As they were on back order, he took a shaft out of one of his inventory and put it in mine. Rides great now.
    Jefflac02 likes this.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
  8. #27
    It appears as though the front prop shaft is going south again. Lots of play at the front diff along with the regular rattling noise.
    I'm not a real hard hitter with this thing, mostly around the farm hauling wood and what not. No jumping or hard hill climbing, ( my god I sound boring ), or any of that so it's got me baffled. Any thoughts? Thanks
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
  9. #28
    (Forde) Administrator fswan's Avatar
    2897 times
    Have not been reading about a lot of problems with the prop shaft w/ the slip joint so it's odd that you have gone through two of them. Obviously, the root cause lies somewhere else. The first thing that jumps out is apparent weight of your machine -- with all your options, that thing's got to weigh a ton! Have you mounted your plow yet this year? Does the problem start minor then get worse over time? Is it worse/better/same when you go into 4WD? Do you spend a lot of time in 4WD? Is it worse/better/same when you have a big load?
    You know why when geese fly in a V, one side of the V is longer than the other? More geese on that side.
    '19 RZR 1000XP EPS Trail and Rocks Edition
  10. #29
    Z71
    Z71 is offline
    (Mike) Elite Member Z71's Avatar
    U.P. of Michigan
    67 times
    These machines are barely built to run stock, mod them up and things start to fail.
    Anoriginal likes this.
    Mike
    2018 RZR S 900 EPS
  11. #30
    May 2012
    Waxahachie Texas
    118 times
    I wonder if the carrier bearing is bad also ? I’m thinking about changing mine to the sandcraft brand.
    17 Crew 1000
polaris tanger 570 drivetrain noise
