Front drivetrain noise - Page 6
This is a discussion on Front drivetrain noise within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Originally Posted by lexiontech I don't want to say it is "normal" but both my 17 1000 and family's 18 900 have a lot of ...
Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Like Tree8Likes
Thread: Front drivetrain noise
  1. #51
    BPS
    BPS is offline
    Regular Member BPS's Avatar
    May 2018
    Everything
    41 times
    Quote Originally Posted by lexiontech View Post
    I don't want to say it is "normal" but both my 17 1000 and family's 18 900 have a lot of play in the front diff yoke you speak of. Now my 17 has almost 6 times the miles on it that the 18 does, and the play in both machines feels the same. Both of them have the clunking noise from the front shaft, the 18 for sure has had the noise since new. Is it just a sloppy design to begin with or has someone actually come up with a fix?
    Poor design in my opinion. There is a fix, it's just $$$. I recently install a new prop shaft from CCI Driveline on a 16 900. Nice piece of hardware.
  2. #52
    (Tom) Veteran Member lexiontech's Avatar
    Feb 2018
    North Central North Dakota
    2017 Ranger 1000 EPS
    80 times
    Good to hear. So all or most of the play was from wear on the prop shaft then? The shaft on the diff was OK? I am wondering if I should take mine apart and have a look. I guess my concern on the issue went down when I found it felt the exact same on our new one after a couple hundred miles. I would hate to have it fly apart out in the woods though.
    2017 Ranger 1000 EPS Bronze - 6500 miles, 760 hours
    Premium roof, electric window doors, sliding rear glass, tip out front glass, wiper/washer, heater
    72 inch steel snow plow
    Warn Winch
    Front brush guard
    Lock and Ride box topper
    Prospector Pro Tracks
    S3 HD Springs
  3. #53
    Regular Member Exlawdog's Avatar
    I’ve come to that realization as well. But, if they put the wrong shaft on it they will stand behind it. They’re good folks and listen to what I find on the forum.
    2017 900xp EPS
    Full cab, w/heat and wipers
    All glass W/tip out front
    All camo
    Hydro dump
    Glacier pro w/ hydro
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    Rear LED in bumper lights
    2" Bracket lift
    28" Attack tires
    Air relocate box
    Dragonfire seat belt bypass
    Custom Bed Rack w/led floods and tool holder
    1500# Winch on Bed Rack
    WhoMoto rock sliders
    More to come
    "I may not be the Boss, but I've got a lot of pull"
    The output shaft was toast as well as the prop shaft.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
  6. #55
    (Monty) Regular Member Monty's Avatar
    Mo.
    11 times
    Ive had some problems with front drive shaft noise vibration replaced it one because Polaris said it was causing headpipe to break did stop a lot of vibs but still broke another pipe a sloppy fit between yoke and pinion seems like I seen a front yoke that was split with 2 clamp bolts to clamp it to the pinion seems like a good idea to stop some of the rattle vibration but cant seem to find it again. probably doesn't help I have 30000 thousand miles on it. Just don't want to replace front diff and drive shaft for $$$ and still have a sloppy fit.
    2013 900 xp tip out windshield steel roof
    poly back glass electric window doors
  7. #56
    As I said both the output shaft and prop shaft were shot. Everything has been replaced and it runs smooth and no more rattle.
    I’m way out of warranty but they only charged me for the parts as I have been squawking about this rattle for a long time. Still no definitive answer as to why it occurs.
    Now we will see if the rattle stays away.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
polaris tanger 570 drivetrain noise
