Front drivetrain noise
This is a discussion on Front drivetrain noise within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Ok here it is....at about 20 hours, I started to hear a rattling noise coming from the front of my machine. I can hear it ...
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Like Tree8Likes
Thread: Front drivetrain noise
    Regular Member Exlawdog's Avatar
    Ok here it is....at about 20 hours, I started to hear a rattling noise coming from the front of my machine. I can hear it best at about 15 mph. It sounds like rocks being rattled in a bucket. I took it to the dealer and they could not find a visible problem. They greased it heavily and that seemed to help for about an hour of driving. The noise returned.
    I am going in to talk to them again (they are very open and supportive) to see if we can figure it out.
    Is there a slip yoke on the front that could be worn? Noise like that has to lead to a failure.
    Any thoughts would be welcome.
    2017 900xp EPS
    Full cab, w/heat and wipers
    All glass W/tip out front
    All camo
    Hydro dump
    Glacier pro w/ hydro
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    Rear LED in bumper lights
    2" Bracket lift
    28" Attack tires
    Air relocate box
    Dragonfire seat belt bypass
    Custom Bed Rack w/led floods and tool holder
    1500# Winch on Bed Rack
    WhoMoto rock sliders
    More to come
    "I may not be the Boss, but I've got a lot of pull"
    Starting Member vrm800's Avatar
    May 2017
    I had a noise like that in mine from New. I found it when I wasn't even looking for it. Turned out to be a bolt that wasn't tightened at all just had the nut turned on. Connecting the front frame to the roll cage in front of the steering wheel.
    Found it when I sealed the cab.
    Sent from my LG-H812 using Tapatalk
    I will look, but the grease stopped the noise for about an hours driving before it returned, thanks.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
    Caribbean
    2001 times
    ELD, greased what ? if it isnt a u-joint, did the dealer check the front brake pads ? Not much to build a case on.............
    Exlawdog and lgall like this.
    Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE. WHOA !
    2007 Polaris Ranger700 XP LE
    They said they greased everything real well. I can actually move each brake caliber by hand, is that normal?
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
    Caribbean
    2001 times
    Quote Originally Posted by Exlawdog View Post
    Calipers should not 'shake, 'rattle or 'roll but loose pads will.
    I just watched a video about brake pad rattle. I will check for that when I get back to the farm.
    The part that confuses me is the rattle disappeared after greasing it and then returned after an hours driving
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
    My dealer just ordered me a new front driveline assembly. However, there are none available for two weeks. That says something in itself I would say.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
    Caribbean
    2001 times
    Is that a new propshaft ? "My dealer just ordered me a new front driveline assembly"
    Yes, in the proper vernacular.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
polaris tanger 570 drivetrain noise
