Second set of wheels/tires
This is a discussion on Second set of wheels/tires within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; I have a 2017 900XP that I want to get a second set of tires and wheels for riding around the county roads in the ...
Results 1 to 6 of 6
  • 1 Post By RJ
Thread: Second set of wheels/tires
    Starting Member Hoyt Ag's Avatar
    Sep 2017
    I have a 2017 900XP that I want to get a second set of tires and wheels for riding around the county roads in the area. I currently have stock wheels and Trilobyte tires that are great for the mud and hunting season. But I want a set of "street" tires for the other 8 months of the year to ride around the area. The hunting tires I have are way too loud on the roads in the area so I am after a second set to lessen the noise when riding around. What are the options I can pursue for this purpose? I see there are lots of take off wheels in the area, but what are some tire options and what size?
    114 times
    I have a set of 14 inch Bandits on order from Superatv.com and will mount a some car tires on. Wheels are 14x7 for $53 each and theres coupons for 10% off. Found some cheap tires on CL so should have setup for under 250
    RJ is online now
    301 times
    I run a set of General Grabbers on 14" rims like this guy did. Super smooth ride for cruising around the back roads.
    https://www.prcforum.com/forum/17-ra...-27-tires.html
    27-11-14 Tusk Trilobites
    G5 tune
    Sep 2017
    Quote Originally Posted by RJ View Post
    This will run a stock set up? I dont have any lifts or anything like that.
    114 times
    You can go to Tyre size calculator site and check various tire and rim sizes.
    Depending on your tire it may well be smaller height on the 14 inch rim so no lift needed
    Your speed indicated would be less than indicated but car and truck tires last up to ten times that of atv tires
    RJ is online now
    301 times
    They are a 27" tire . No lift needed.
    summermn likes this.
    G5 tune
  1. XP1K NEW Factory set Tires/Wheels
    By Bamamastiff44 in forum Member Classifieds
    Last Post: 06-03-2014, 11:39 PM
  2. Speaker System set up ???(Re-doing My Set Up with pics)
    By Hlinville in forum General Member Discussions
    Last Post: 03-08-2013, 11:10 AM
  3. Set of tires and wheels
    By Ned in forum Member Classifieds
    Last Post: 02-19-2013, 10:07 AM
  4. Set of 26" PXT tires on Camo Wheels. 2 Miles on them.
    By family adventure in forum Member Classifieds
    Last Post: 01-03-2010, 11:46 AM
  5. Replies: 1
    Last Post: 05-16-2008, 04:40 PM
