Light Bar DONE!
Light Bar DONE!
This is a discussion on Light Bar DONE! within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; 20" light bar installed. Was super easy using existing holes behind the bumper. Items used, 6" by 1 1/2" black pipe, cut into two 1 ...
Results 1 to 7 of 7
  • 2 Post By Ranger D
Thread: Light Bar DONE!
    (Dave) Starting Member Ranger D's Avatar
    MN Iron Range
    2019 Ranger XP 900
    Light Bar DONE!
    Items used,
    6" by 1 1/2" black pipe, cut into two 1 7/8" pieces
    3" by 36" 1/8" thick steel plate, cut to 20" length
    Two 2 1/2" by 3/8" stainless bolts
    Two 3/4" by 3/8" stainless button head bolts
    Four stainless nylock nuts
    Two 1" by 3/8" stainless fender washers
    The existing holes are 18" on center. I drilled two 3/8" holes at 18" on center 3/8" from the back side of the plate. Using the 1 7/8" pieces of pipe as stand-offs I mounted the plate. I put the fender washers under the bumper support to spread the load a bit more. I temporarily mounted the plate to determine where to drill the holes for the light bar. Once i had that figured out i pulled the mount off and drill the light bar holes. Put a few coats of paint on it and mounted it back on the machine. Came to realize my 3/4" bolts interfered with the adjustment on the light so had to grind the down with my angle grinder.
    Wire it up using a relay mounted under the hood and a Sasquatch rocker switch in the cab.
    Light came from eBay and included four pod lights as well.
    Also installed Moose Industries seat covers.
    Stroke250 and jobo2856 like this.
    2019 Ranger XP 900 Premium
    Polaris Sport Roof
    KFI Rear Tube Bumper
    Polaris 4500lb Winch
    Polaris Rear View Mirror
    20" LED Light Bar
    Moose Industries Seat Covers
    2016 570 Sportsman
    Polaris Mid Smoke Winshield
    Polaris Mirrors
    Polaris 2500lb Winch
    Starting Member jimh406's Avatar
    Western Montana
    2017 Ranger 570 Mid
    17 times
    Looks like it just fits, and looks good.
    2017 Ranger 570 Midsize, stock tires/wheels with a few accessories like bed rack, roof, windshields.
    (Sam) Regular Member samhallnc's Avatar
    Sep 2018
    2018 Ranger 900 XP
    43 times
    Looks great.
    106 times
    Should do a good job of lighting up the hocks on a moose.
    Have you considered getting led bulbs for the headlights? Made a big difference on my 900 from a candle yellow to lot brighter white and one can turn the bulb to get the most out of the emitters.
    Starting Member BowHunter148's Avatar
    What bulb kit did you buy ?
    (Mike) Supporting Member PalaceRat's Avatar
    Mar 2016
    Daytona Beach, Florida
    2016Ranger 900XP EPS
    174 times
    I used Beamtech H13 bulb on my 2016 Ranger and it really eliminates the yellow light. Make sure the LEDs are at the 3 o'clock and 9 o'clock position when you install them to get the most our of the existing reflector.
    2016 Ranger 900 XP EPS Sunset Red
    Lock & Ride Pro-Fit windshield
    Lock & Ride Pro-Fit Sport Roof
    Lock & Ride Pro-Fit rear wind screen
    Lock & Ride Bed Rails
    IDD Display with backup camera
    Polaris 13" LED light bar
    Beamtech H13 Led Headlight bulbs
    MMA 2.5 inch lift kit
    STI HD6 Alloy wheels
    STI 27X14 Roctane XD tires
    Polaris Bed Liner
    K-Winch 4500
    UTV Dirt Stoppers
    Trail Armor Skid Plate
    UTV TEK Trio HD 2" Hitch
    Green Mountain Outdoors Camo seat covers
    6" Round LED Backup light
    Super ATV steering wheel
    LED dome light
    Starting Member devonj's Avatar
    I installed the Beamtech H13 bulb as well, but after doing a lot of reading and watching videos, I learned that it is best to install them vertical. This will give you the true low beam flood and high beam. Once you install them, you will want to check them on both low and high beam against a wall. I had one bulb 180 degress out and had to take it back out and rotate it. After that, I had to lower them both from the factory position because they were too high on low beam. Awesome!
  1. Light Bar Wires Inside the Roll Bar
    By Outlaw6.0 in forum Ranger XP 900 & 570 FS Discussions
    Last Post: 06-13-2014, 01:49 PM
  2. Need ideas - Light bar, flashing light fixture???
    By Kevin Immink in forum Ranger XP 900 & 570 FS Discussions
    Last Post: 04-14-2013, 10:25 AM
  3. LED light bar vs. LED standard round light
    By hardaway in forum Ranger Discussions
    Last Post: 12-01-2012, 07:44 PM
  4. Light the night, Rigid LED light bar
    By Archer-x in forum Ranger Discussions
    Last Post: 04-19-2010, 03:03 PM
  5. light bar/ pre-runner bar
    By XP Dave in forum Ranger Technical
    Last Post: 12-23-2008, 08:46 PM
