Polaris heater detailed instructions - Page 2
This is a discussion on Polaris heater detailed instructions within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Great write up and some great tips. Looks like a really nice/ clean install....
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Like Tree5Likes
Thread: Polaris heater detailed instructions
    (Carl) Elite Member Seastacker's Avatar
    Feb 2013
    226 times
    '13 Ranger 500 EFI (Red)
    26" Outlaw MST tires, MSA Elixr wheels. Polaris sport roof. Polaris half windshield and EMP full fold down windshield. EMP canvas back panel. Mud Guard kit front and rear. Viper Max 4000# Winch w / Synthetic rope. Polaris rear bumper, Lock and ride chainsaw scabbard. Odyssey 925 battery.
    Other stuff:
    01' Ford F-250 Diesel
    85' Honda ATC 250R
    (Neal) Retired Moderator oneal's Avatar
    Aug 2005
    Ohio
    28 times
    Quote Originally Posted by Seastacker View Post
    Thanks Carl
    Neal
    Today is my personal best for most consecutive days alive.
    (John) Elite Member TD-Max's Avatar
    Mar 2009
    Central WI
    I've had mine out in sub zero weather and the heat output is outstanding when the RPM's are up. When idling the temp drops back a bit, but still very good.
    The only addition I'd suggest is that the "from engine" hose be attached to the lower port and the return on the upper. This method should work the air out much more effectively.
    I like the way Neal put actual holes in the floor versus slots.
    The expanding foam is not a bad idea, but with the heat output this thing makes it shouldn't be necessary. I did a lot of extra caulking for seam sealing on mine and really doubt it was necessary.
    Here is the one that I did last year:
    2013 XP 900 Browning
    Premium roof, solid rear glass, tip out windshield, pivoting window doors, rear bumper, Polaris heater/defroster kit
    (pierre) Elite Member pierre jean's Avatar
    PQ. canada
    70 times
    Good to hear it work great , hir in Québec -25 -28 deg.far. this week , should put the heater next week , wait from polaris for the doors
    Pierre Jean
    (Andre) Regular Member andre's Avatar
    May 2013
    Ontario Canada
    same temp here Pierre (Sudbury)... and the heater works great.
    Aug 2005
    Ohio
    28 times
    Quote Originally Posted by pierre jean View Post
    Good luck, don't hesitate to PM me if you have any questions !
    Neal
    (Jim) Elite Member catmanLE's Avatar
    Pa.
    69 times
    Oneal, could you post some pictures of the finished dash and such, your pictures seem exceptionly clear and bright, and what doors are you running on the 900, and did you get a seal kit with your doors?
    PQ. canada
    70 times
    Quote Originally Posted by oneal View Post
    Thank , Neal my wife send you BIG KISS HIHIHI!!!!
    Pierre Jean
    Aug 2005
    Ohio
    28 times
    Neal
    (Terry) Regular Member TerSans's Avatar
    Jul 2008
    Gold Creek, Montana
    Great job. I noticed after I put my heater in that the zip ties Polaris uses to fix the flex tube to vents did not hold the flex tube connection very well. After a rock ride, very bouncy, there was enough banging about that several to the flex connectors had come off of the vent fixture. I spread, using my finger, some silicone adhesive inside the flex tube and on the vent connection and then put the flex back on. Since then I have had no flex come off the vent connector.
    supersmith likes this.
    2013 Ranger 900 XP LE EFI EPS
    Orange Madness on ITP BahaCross tires 14" SIXR wheels, Camoplast 4 Season tracks,
    Full steel cab w/heater, tip out windshield, power windows, GPS, Aluminum floor, Polaris audio with Sirius XM, headliner speakers and outside waterproof front speakers, Galaxy s4 cradle, rear view video monitor mirror with rear and front view cameras, Extreme bumpers front and rear, Nerf bars, Polaris 4500 winch front, 4500 Venom winch rear w/remote wireless controllers, full Aluminum gear box and Aluminum deck cover over rest of bed, LED rear service and backup lights, Polaris LED light bar in front on bumper, 42" LED 240 watt double row Cree light bar on roof, EMP Armor front and rear arm covers,
    Custom paint
adding vents to polaris ranger
direction of coolant flow polaris ranger 900
polaris 2879967 instructions
polaris 900 xp ranger 2015 heater hose connection placement
polaris heat hoses
polaris heater kit installation directions
polaris ranger 900 heater install
polaris ranger heater forum
polaris ranger heater installation instructions
youtube what is the best place to connect heater hoses on a 2015 polaris 900 xp ranger
