Polaris heater detailed instructions - Page 3
This is a discussion on Polaris heater detailed instructions within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Originally Posted by pierre jean Good to hear it work great , hir in Québec -25 -28 deg.far. this week , should put the heater ...
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Like Tree5Likes
Thread: Polaris heater detailed instructions
    (pierre) Elite Member pierre jean's Avatar
    PQ. canada
    70 times
    Quote Originally Posted by pierre jean View Post
    Good to hear it work great , hir in Québec -25 -28 deg.far. this week , should put the heater next week , wait from polaris for the doors
    Heater was on , work great , all i changed is the cheap tie raps , put 2 goods one at end of each hose , for be safe , just whait for doors now . New problem , the sheafter wire freeze now ????
    Pierre Jean
    PQ. canada
    70 times
    Waithing again for the doors ??????? was order last november ?
    Pierre Jean
  3. #23
    (Jim) Elite Member catmanLE's Avatar
    Pa.
    69 times
    Thanks Oneal your write up just helped out quite a bit, especialy the tip on cutting to the inside of the scribes on the panels!!!
    Veteran Member Tushar's Avatar
    How do I get the fan to blow? Ive hooked everything up and the fan isnt putting out any air. Can someone tell me how the wiring is supposed to be connected. I thought I did it correctly but apparently something isnt working right. Thanks
  6. #25
    Never mind. I think I've got the wiring figured out. The pictures in the instructions are wrong. After moving the wires all around I got the fan to work. I thought I got a defective fan and was just about to pull it out and return it. The red and yellow wires go together on the first terminal and I put the black wire under the torx screw. Name:  ImageUploadedByOff-Road Forums1428185664.627002.jpg
  7. #26
    Regular Member POLARISXP900's Avatar
    15 times
    I used your write up to familiarize myself before tackling the job. Made it go smooth
    TG-OK likes this.
  8. #27
    Starting Member netdefilr's Avatar
    Oct 2016
    How do you snug the rubber hoses on the nozzle connections on the heater? Seems like I can't get it on there easy.
    After drilling the holes Im assuming to take off the nuts that are on the bolts and tighten them up from the other side? Ive dropped 3 nuts and cant find them with this approach. Tried using a couple magnets. Is there a better approach? Its hard to reach.
  9. #28
    15 times
    Quote Originally Posted by netdefilr View Post
    You could have a buddy hold the heater box in place while you start the nuts from the outside. But I didn't find that necessary as it stayed in place with the static tension for me to get out and start the nuts.
    As far as getting the hoses on the heater core nipples, yes it did take some twisting and pushing but nothing out of the ordinary.
    I was plowing the other day and had to switch the temp form red to blue as it gets to warm. Love the OE heater
  10. #29
    Regular Member kryptek's Avatar
    Nov 2017
    11 times
    On my install I dipped the hose ends in radiator fluid and I also put the hose ends on before mounting it to the fire wall.
    Also I love the Polaris heater too. I went from red to blue too while plowing!
  11. #30
    (Dean) Starting Member coyotegetter's Avatar
    Dec 2017
    Winsted Mn
    2013 polaris ranger 900xp full cab
    Im still trying to seal up my cab on my 2013 ranger. I bought it used a month ago. It has the seal kit installed already. I used the expanding foam to seal the dash and i t helped alot but still leaks by the drivers side cup holder. What am i missing ? Your post was very helpful And the only thing i found. Thanks Dean
adding vents to polaris ranger
direction of coolant flow polaris ranger 900
polaris 2879967 instructions
polaris 900 xp ranger 2015 heater hose connection placement
polaris heat hoses
polaris heater kit installation directions
polaris ranger 900 heater install
polaris ranger heater forum
polaris ranger heater installation instructions
youtube what is the best place to connect heater hoses on a 2015 polaris 900 xp ranger
