Polaris heater detailed instructions - Page 4
This is a discussion on Polaris heater detailed instructions within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Originally Posted by coyotegetter Im still trying to seal up my cab on my 2013 ranger. I bought it used a month ago. It has ...
Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Like Tree5Likes
Thread: Polaris heater detailed instructions
  1. #31
    (SlimRockett) Elite Member SlimRockett's Avatar
    May 2012
    Waxahachie Texas
    118 times
    Quote Originally Posted by coyotegetter View Post
    Im still trying to seal up my cab on my 2013 ranger. I bought it used a month ago. It has the seal kit installed already. I used the expanding foam to seal the dash and i t helped alot but still leaks by the drivers side cup holder. What am i missing ? Your post was very helpful And the only thing i found. Thanks Dean
    Is the steering shaft sealed off at firewall?
    17 Crew 1000
    2017 Ranger Crew 1000 Bronze
  2. #32
    (Tony) Elite Member arcticzale's Avatar
    Mar 2017
    Yooperland
    509 times
    I had the same issue. I sealed up behind the cupholders from behind/underneath with some foam mat. Helped a lot but also had to seal the gaps where the fender meets the door jam.
    Attached Images Attached Images
    Ranger Crew 900-5 EPS LE Sunset Red with a whole bunch of stuff.
    Build thread: Arcticz Crew Build
  3. #33
    Regular Member POLARISXP900's Avatar
    15 times
    I did the seal kit because it came with the doors but beyond that I didn't do anything else. It can get to single digits or below where I live and at least for plowing, I find it gets to hot in the cab and always have to lower the heat. I guess maybe if I was driving at speed on roads I would feel a need for more sealing ? Is that when you feel the cold air coming in?
    Mar 2017
    Yooperland
    509 times
    Quote Originally Posted by POLARISXP900 View Post
    I did the seal kit because it came with the doors but beyond that I didn't do anything else. It can get to single digits or below where I live and at least for plowing, I find it gets to hot in the cab and always have to lower the heat. I guess maybe if I was driving at speed on roads I would feel a need for more sealing ? Is that when you feel the cold air coming in? [IMG class=inlineimg]http://www.prcforum.com/forum/images/smilies/tennis.png[/IMG]
    For me, the same is true. It's above speeds you would see if you were just plowing.
    POLARISXP900 likes this.
adding vents to polaris ranger
direction of coolant flow polaris ranger 900
polaris 2879967 instructions
polaris 900 xp ranger 2015 heater hose connection placement
polaris heat hoses
polaris heater kit installation directions
polaris ranger 900 heater install
polaris ranger heater forum
polaris ranger heater installation instructions
youtube what is the best place to connect heater hoses on a 2015 polaris 900 xp ranger
