'11 800 xp ECU REFLASH HELP
This is a discussion on '11 800 xp ECU REFLASH HELP within the Ranger Discussions forums, part of the Polaris Ranger Forums category; Hi all, I've recently purchased a 2011 800 ranger xp and have had plans to upgrade it continuously for my preferred type of riding. The ...
Thread: '11 800 xp ECU REFLASH HELP
    Starting Member Harrison's Avatar
    Apr 2019
    Tuscaloosa AL
    Post '11 800 xp ECU REFLASH HELP
    Hi all, I've recently purchased a 2011 800 ranger xp and have had plans to upgrade it continuously for my preferred type of riding. The only thing is I've hit a major stump. I cannot for the life of me find anyone that does ECU re-flashes for this year and engine size. I originally planned to go with an auto tuner only to find out the Power commander V that "fits" my machine doesn't really fit at all, it is meant for the rangers with the battery directly under the seat, not under the hood. So after doing a ton of research on other forums (and this one) I've pretty much come to a dead end. I understand it is not necessarily a need for this machine but to be honest I really want the extra top speed, higher rpms, and richer fuel to air ratio. Almost enough for me to turn around and sell it and get a used 900 if I can't find a solution lol(solely because of the amount of tunes and accessories that are still being made and sold for them, not even really because of their increased power at stock). If anyone has any ideas I am all ears as I have already ordered harnesses, a lift kit, spacers, and tires to be coming soon, I really want to build this machine up as opposed to turning around and restarting the process with another one. Thanks, and look forward to reading some of your responses.
    Starting Member Ditch1000's Avatar
    Sep 2015
    Fort St. James, BC
    Quote Originally Posted by Harrison View Post
    Hi all, I've recently purchased a 2011 800 ranger xp and have had plans to upgrade it continuously for my preferred type of riding. The only thing is I've hit a major stump. I cannot for the life of me find anyone that does ECU re-flashes for this year and engine size. [IMG class=inlineimg]https://www.prcforum.com/forum/images/smilies/mad-new.png[/IMG] I originally planned to go with an auto tuner only to find out the Power commander V that "fits" my machine doesn't really fit at all, it is meant for the rangers with the battery directly under the seat, not under the hood. So after doing a ton of research on other forums (and this one) I've pretty much come to a dead end. I understand it is not necessarily a need for this machine but to be honest I really want the extra top speed, higher rpms, and richer fuel to air ratio. Almost enough for me to turn around and sell it and get a used 900 if I can't find a solution lol(solely because of the amount of tunes and accessories that are still being made and sold for them, not even really because of their increased power at stock). If anyone has any ideas I am all ears as I have already ordered harnesses, a lift kit, spacers, and tires to be coming soon, I really want to build this machine up as opposed to turning around and restarting the process with another one. Thanks, and look forward to reading some of your responses.
    Go with a Bikeman 800 powe and speed kit...
    You get their clutching plus the power commander 5... It will be a way better machine than the stock ranger, it wil also run cooler because of the better fuel map...
    Also, Move your voltage regulator from in front of the radiator to under the hood... That will make it run a few degrees cooler as well...
    I did the 800 big bore after I blew my motor a few years ago... It was a huge upgrade over stock!!
    2010 Ranger 800XP, Bikeman 800 Bigbore with high performance camshaft, clutching, PCV, High Capacity Radiator, 27" ITP Mudlites, Diamondback Roof, Prolift 2" lift kit, stereo and in-cab heater.
    (Josh) Elite Member move's Avatar
    Mississippi
    11 times
    The Power Commander and Auto Tune sold for the RZR-S 800 is what I originally bought and used for years. They are the exact same engine. Dyno Jet will tell you they aren't only because they have not verified it themselves. Back in 2011 or 12 Bikeman was very helpful when I purchased my Power Commander from them.
    I can only assume the elements finally got the best of my Power Commander causing me to pull it off.
    2011 Polaris 800 Ranger Browning Edition
    Backwoods Armor arched control arms, SuperATV steering assembly, SuperATV axles, 29.5 OL2, STI HD1 14" wheels, Looney Tune Exhaust, Turf mode delete Transmission, Billet front diferential, Spal Fan
  1. reflash ecu and programmers
    By r_marczak_83 in forum Ranger XP 1000 Discussions
    Last Post: 02-25-2017, 01:29 AM
  2. ECU reflash comparisons/satisfaction
    By r_marczak_83 in forum Ranger XP 900 & 570 FS Discussions
    Last Post: 01-11-2016, 11:48 AM
  3. 570 ECU reflash?
    By Rustyman14 in forum Ranger XP 900 & 570 FS Discussions
    Last Post: 12-14-2015, 09:07 PM
  4. 2014/15 Ranger 900 Reflash ECU
    By Empire Industries in forum Ranger Crew Discussions
    Last Post: 08-07-2015, 09:29 AM
  5. 2014/15 XP 900 ECU Reflash
    By Empire Industries in forum Ranger Crew 900 Discussions
    Last Post: 06-08-2015, 08:05 PM
Tags for this Thread
