Wireless winch remote battery?
This is a discussion on Wireless winch remote battery? within the Ranger Discussions forums, part of the Polaris Ranger Forums category; It occurred to me that I might need to carry a spare battery for the wireless winch remote since it would be impossible as far ...
  • 1 Post By summermn
Thread: Wireless winch remote battery?
    Regular Member Ronmcc4's Avatar
    Question Wireless winch remote battery?
    It occurred to me that I might need to carry a spare battery for the wireless winch remote since it would be impossible as far as I know to operate the winch without it. But, upon examination, there is no obvious way to replace a battery inside the remote short of disassembling it. And, there is no mention of a battery in the remote in the winch installation instructions or the Polaris user manual. There must be a battery in there and batteries eventually need replacing. Does anyone have any information about the wireless winch remote battery/power source?
    Elite Member summermn's Avatar
    203 times
    Amazon and rockymountainatv both state a 23a/12 volt. Have not googled for how to crack that nut
    Makes sense - I think I already have some of those batteries at home for something else. The first time I read your reply summermn I thought it said 23 amp - say what! . Then I realized what you meant. Thanks for the info!
    203 times
    I have them in some remote lighting controls and garage door openers
    Google is your friend-just don't tell Alexa
    yooper265 likes this.
    Regular Member TND2018xp's Avatar
    Apr 2018
    Northern Michigan
    2018 XP 1000
    30 times
    The first time I went to actually use my winch the battery in the remote was dead. I then wired in a corded remote with help from people on here.
    Make sure that you have a good screwdriver with you if that is your plan. I think it was a JST (?) not just a standard Phillips. Mine came apart rather hard.
    (Jim) 1000+ Member Natethedog's Avatar
    Nevada
    798 times
    In addition to the wireless remote, my viper winch can be operated by a wired switch inside the cab. There must be a way to wire up a similar system in your rig. A spare battery is a good idea, but not much good if you lose the remote. Mine has disappeared for a day or two more than once. Good luck!
    2013 Ranger XP900 LE EFI EPS, Member 10,000+ Mile Club, Viper Elite 5000# Winch, Dragon Fire 1/2 Doors, THE Duraclutch, Firestorm Heater, 12" Totron combo light bar front and flood cubes aft, DIY game loader, Bandit Shocks
    (Joe) 1000+ Member jaybey's Avatar
    Nov 2005
    Tucson- Joe
    184 times
    I suggest the obvious, contact the manufacture of you winch and ask them how to change the battery. It most likely be stupid simple!
    Freedom has a taste only those who have fought for it will ever know.
    If guns are outlawed only outlaws will have guns. An armed society is a polite society.
    FEAR THE GOVERNMENT THAT WANTS TO TAKE AWAY YOUR GUNS!
    2015 Ranger 900 XP EPS, Polaris tip out windshield, glass rear window, Polaris canvas doors. 3600 lumen driving lights, TMH 20'' Dual Row High Power 126w Cree Light Bar 13000 Lumens
    , led driving lights for back up light, EZ turn signal kit, Garmin Montana 600, UMC ATV tool/storage box, Ricochet rock sliders, home made mud blockers, in bed mounted spare tire, Big Sky roof mount gun rack, Wolo Bad Boy air horn.
    PRC # 1164
    Life Member NRA & Golden Eagle Member
    Joe - Tucson, Arizona
    Got a small pack of A23 batteries so I should be good to go. A wired remote wouldn't be a bad idea either but that's a project for another day. Thanks all for the info.
    Regular Member Dbonzi's Avatar
    May 2018
    S Minnesota
    2019 Northstar Crew
    21 times
    I have the Polaris 6000 winch with the remote. I took mine apart a while ago. If it is the same remote as the 4000, the battery does come out. But you wouldn't want to do it out on the trail. And yes you can put a switch in the dash.
    Dennis
    2019 Northstar Crew
    No Hole Signals
    Visor Audio System
    Rock Lights
    Rear Led Cube Lights
    PRO HD 6,000 LB. WINCH
    GLACIER® PRO HD PLOW
    Starting Member wfolds's Avatar
    Bradenton, FL
    Ranger 900XP ESP
    Dbonzi thanks for the response. I took the remote apart further and you are correct that the battery is replaceable. Maybe I should investigate more before jumping to a conclusion that is incorrect. I guess you are never too old to learn a lesson. One other question. Do I loose my link to my winch when I change the battery? Also do you know of instructions on how to add a switch to the dash. Thanks again for the response and education.
    Walt
  1. Wireless remote winch
    By ronster_12 in forum Ranger Discussions
    Last Post: 11-15-2012, 10:51 PM
  2. Will the polaris wireless winch remote hook up to 4500 winch
    By Almost Heaven in forum Ranger Problems & Solutions
    Last Post: 01-05-2011, 12:08 PM
  3. SUPER ATV 4500 LB WINCH WITH WIRELESS REMOTE
    By SuperATV in forum RZR Discussions
    Last Post: 10-25-2010, 08:46 AM
  4. SUPER ATV 4500 LB WINCH WITH WIRELESS REMOTE
    By SuperATV in forum Ranger Discussions
    Last Post: 10-25-2010, 08:36 AM
  5. Warn Winch Wireless Remote
    By Panhead64 in forum RZR Technical
    Last Post: 05-14-2008, 01:39 PM
