Securing ranger to trailer setup critique
This is a discussion on Securing ranger to trailer setup critique within the Ranger Discussions forums, part of the Polaris Ranger Forums category; Before I start bolting the hardware down like to get a bit of feed back. Hate doing something twice because I had a brain fart. ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree9Likes
Thread: Securing ranger to trailer setup critique
    159 times
    The front is being secured with Erickson chock and straps. The rear is being done with etrack and 1k working load straps with the straps being secured to the ranger with quick links
Size:  855.0 KBName:  SAM_0112.JPG
Size:  793.8 KBName:  SAM_0113.JPG
    Stroke250 likes this.
    (ron) Elite Member wgarcar1's Avatar
    Jun 2016
    vero beach, Florida
    226 times
    I think that you need :
    A. To get a 1/4" metal piece from under the wood in the rear and there is a heavy duty 2" (thicker) E-track with 3" bolts and nuts.
    B. Definitely 2" E-track heavier duty straps to the floor.
    But that's only my opinion
    Sent from my SM-G950U using Tapatalk
    2018 ranger 900 XP full size. from sky motorsports of Lake wales fl
    KOLPIN 6.0 gun boot+bed mount for the AR. from kolpin.com
    KOLPIN KXP Rhino Grip XL Double Set for Polaris Ranger Lock N Ride UTV 21517
    Multi-Vent front Shield W/HardCoat (77-9525) and rear(77-9600). from utvheadquarters.com
    heavy duty aluminum roof. from Marty at whomoto.com
    Hornet R-3024 Ranger Hi Lift UTV Jack and mount. from ebay
    20" LED green Light Bar/120 Watts/Waterproof. from TexStar Lighting 936-337-4333
    6" round white LED lights under bed. from ebay
    4500 lb KFI front winch. from ebay
    ITP MUDLIGHT XL tires ( 25 x 11-12; 489 on fronts and 25 x 12-12; 489 on rears) no rubbing from ebay
    POLARIS brush guard. from polaris
    159 times
    Yes on steel under the wood. 1 1/2 inch angle iron
    The rear straps are work rated at 1000lbs each with breaking at 3000 with a pair they should yield 6000 lb breaking and no open hooks with this setup to come off if the straps get loose.
    The Erickson wheel chocks with straps are rated for 1500lbs for the pair exceeding the 900xp's weight.
    The biggest hurdle I have found is that with the engine behind the seat getting 300 or so lbs on the trailer tongue to give the Xterra some rear grip
    wgarcar1 likes this.
    (Rob) Veteran Member Griffon's Avatar
    Nov 2015
    Wisconsin
    151 times
    I tow with an Xterra as well. I hear where you are coming from. I tow about 300 miles or more nearly every weekend to attend shoots.
    I went with a heavy duty E-track the length of the trailer with Erikson e-track chocks to allow me to fine tune placement of the ranger on the trailer ( I put a loaded 60 qt pelican cooler in the bed of the ranger one day - that was an interesting ride.)
    I use the Erikson tire straps on all 4 tires. Trailer is still usable for other things this way.
    Name:  tire strap.JPG
    blackfly53 and jobo2856 like this.
    2018 1000XP Northstar
    2016 900XP Northstar SOLD
    Superwinch Tera 45s
    Denali Pro 72" with Hydro-Turn
    Upgraded to tip-out front windshield
    Aluma 7712H trailer with Prolockers
    2018 Northstar Projects: griffon-s-2018-xp100-northstar-projects
    2016xp Projects: 900xp-northstar-projects
    Custom PRC Search" https://cse.google.com/cse/home?cx=0...saktoixe&hl=en
    Regular Member blackfly53's Avatar
    Sep 2018
    29 times
    The ranger doesn't crush the e-track whatsoever? I know its fairly sturdy stuff but curious if the constant riding over it will cause it to crush.
    2019 Ranger XP900 EPS
    Poly doors with power
    Front and back hardcoat poly windshields
    Poly roof
    Cab seal kit
    SuperATV #4500 winch
    HMW skid plates
    Polaris dome light kit
    Homemade rear mud guards
    FrogSkinz intake covers
    12" Auxbeam LED lightbar
    Auxbeam LED headlight bulbs
    Reverse lights
    159 times
    Reese etrack that I got is 12 gauge. The ranger is under 1500lbs and if tire is only 400 pounds per thats not that much. Probably more if you walk on it. I have seen similar setups with the tires straddling the track and using just strapping into etrack rings
    431 times
    Nissan Xterra? You must be kidding... Have fun changing those spark plugs dude! Hey, trailer setup looks good. Especially with the steel plate underside.
    Veteran Member TX 3400XL's Avatar
    Nov 2018
    67 times
    Looks like a good setup ...I get what your saying on the rear strap strength and they will be fine for securing the ranger on the road......but I would want bigger straps. Those are what will stop it from coming thru the back of your vehicle should you be in a wreck....get those big pretty yellow straps for safety...they're not expensive
    That's why the steel backing plate and bigger straps.
    1198 times
    I don't have a E track on either of my trailers which are aluminum. The deck is wood on both. So I put heavy recessed flip up D rings bolted to the deck and then I welded some short lengths like 4" long x 1/4" thick aluminum angle vertical along the flat sides of the trailer. So if the tiedown point doesn't fall on the D ring it will hit the angle tie down point. When I'm driving I never want to second guess myself "is the load secure". No I want to drive like hell and know the load is before I leave. I use a lot of straps and don't have to guess or wonder.
    2014 900 XP EPS.....28"Mongrels- forward 'A'arms- Rhino axels-MMA lift-Duraclutch-Viper winch-canvas doors-DragonFire doors-Elka stage2 shocks- Gilomen tune and other add'ons
    "Happiness isn't having everything you want, its wanting everything you have"
    159 times
    Quote Originally Posted by Rangerwhit View Post
    Already have changed the plugs along with a new radiator to prevent the milkshake of death. Job was not bad with help of a forum that had good tips on just partially removing intake. Afternoon with a 6 pack. Main reason I ended up with the X was dealer was screwing over the owner on getting the 90k all fluid change and plugs. $1800
  1. Securing my XP1000 to my trailer..... questions
    By mjbuck in forum Ranger XP 1000 Discussions
    Last Post: 09-10-2018, 10:05 AM
  2. securing ranger to trailer
    By 900cfi in forum Ranger Discussions
    Last Post: 04-07-2010, 01:45 PM
  3. Securing RZR in Toybox without straps or ratchets
    By LTZ470 in forum Trucks/Trailers/RVs/Campers
    Last Post: 02-11-2009, 09:32 PM
  4. Lock & Ride Cab -- My Critique w/ Photos
    By Ran in forum RZR Technical
    Last Post: 02-26-2008, 07:55 PM
