Is anyone having clutch problems with their 2019? - Page 4
This is a discussion on Is anyone having clutch problems with their 2019? within the Ranger Discussions forums, part of the Polaris Ranger Forums category; So a mass produced shim for a buck or so could eliminate the P90X belt smoking when using engine braking or Polaris could just not ...
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Like Tree7Likes
Thread: Is anyone having clutch problems with their 2019?
  1. #31
    171 times
    So a mass produced shim for a buck or so could eliminate the P90X belt smoking when using engine braking or Polaris could just not make the braking as aggressive in the first place?
    I wonder if this is the issue BPS is referring to? I talked to the service staff at the dealer yesterday and they have not seen any return for anything other than returns for fluid changes on the new body style 1000xp
  2. #32
    Starting Member J.A.B's Avatar
    Jun 2019
    First post here...
    I have a 19 Ranger XP1000 with about 40 hrs on it, thought I would share my experience with the clutch issues. I am by no means an expert on these clutches but I do own a 13 RZR XP 900 and a 17 RZR XP 1000 so I'm familiar with the how they can be problematic as well as how noisy they can be. This ranger clutch does some weird stuff, it can feel like it's fully engaged in high gear but drive a little bit and it pops out ( probably more a transmission engagement issues than the clutch ), but the real strange thing is the noise it makes idling in park, especialy when it's warm. Say you've been driving it for a few mins, stop put it in park to do something and you can hear the clutch slowly start turning then get faster and faster, like it's trying to engage and slipping the belt, it also gets louder until it's finally put back into a gear. I haven't been into it or taken it to the dealer but it does almost all the time now, I just don't let it idle and cut it off when I stop.
    It seem to function fine otherwise but I'm sure something is not right in there.
  3. #33
    RJ is offline
    316 times
    Quote Originally Posted by J.A.B View Post
    First post here...
    Go to Gilomens site, the one i posts the vid in. He has a vid i think, or instructions on clutch alignment. To me, that sounds like the problem your having.
    27-11-14 Tusk Trilobites
    G5 tune
    (Todd) PRC Sponsor Hunterworks's Avatar
    Jan 2012
    338 times
    Agreed, mine does the same thing, alignment is off so hard to get in gear and when in neutral it turns the secondary and I can hear it good through the snorkels
    Todd Eldridge, Owner of Hunterworks
    www.hunterworks.com
    [email protected]
    601-771-0070
  6. #35
    RJ is offline
    316 times
    Hard to guess if that was the issues or not? when i heard about it a year ago bigger tires and a lot of downhill played a roll in exaggerating the grooving of the belt. Maybe a crew loaded down with gear and people could cause it also? Hard to say. On the other hand, my buddy just rolled over 4000 miles on the new clutch without any issues.
    G5 tune
  7. #36
    (Bob) Veteran Member rbarre's Avatar
    May 2013
    Danville,VT left NJ forever
    67 times
    Quote Originally Posted by Hunterworks View Post
    TRust me, they look at it differently than you think. It gets down to pennies
    As a owner of several from new Ford pick ups over the years and have retired from working for a European new car manufacturer, I can tell you that cost is every thing. Material cost and final manufacturing of part comes down to make it a cheap as possible and yet pass Federal regs. for minimum durability.
    For example my new from 2011 F150 had rotted front and rear brake rotors at around 20K miles it could have been less mileage. the number 1 cause in my opinion is that rotors from factory probably have less nickel content (for cost savings) thus making them corrode easier.Replacement aftermarket rotors are much better with minimal oxidation (corrosion)
    Also tires from factory are made at a very reduced cost also to save money, same vehicle and had to replace all 4 tires due to a belt shift at a very low mileage
    Again the bottom line is pennies per vehicle adds up and the out come is profit.
    Hunterworks likes this.
    2013 900 xp LE with EPS Sunset Red
    poly roof
    tip out glass windshield with wiper/washer
    soft doors
    poly rear glass
    Polaris heat/defrost
    Polaris Glacier Pro 72" steel plow w/ hyd lift and angle
    4500# Viper winch 3/8 steel cable
    S3 Springs Front and Rear lifted it 2"
  8. #37
    1226 times
    I agree with Bob , pennies add up. But what about battieries Bob. I've never ever seen a aftermarket battery last 10 or 12 years like the factory installed battery. Factory truck and car batteries last. Why is that ?
    2014 900 XP EPS.....28"Mongrels- forward 'A'arms- Rhino axels-MMA lift-Duraclutch-Viper winch-canvas doors-DragonFire doors-Elka stage2 shocks- Gilomen tune and other add'ons
    "Happiness isn't having everything you want, its wanting everything you have"
  9. #38
    (J.D.) Regular Member NotAnEngineer's Avatar
    Mar 2018
    Rankin, MS
    2018 Ranger 1000XP
    16 times
    First post here...
    My '18 1000 made that same noise you described for a while. It eventually stopped making it.
    '18 Polaris Ranger XP 1000
    28" BKT's on 14" MSA M33
    Harbor Freight winch
    "Theory is when you know everything but nothing works.
    Practice is when everything works but no one knows why."
  10. #39
    Elite Member aczr2k's Avatar
    Mar 2007
    NW Minnesota
    30 times
    Quote Originally Posted by stainlessman View Post
    Because when your vehicle is new so is everything else... wiring, alt etc. Not all new OEM batteries are great either, Case in fact Polaris batteries...back in the mid 2000's you were just lucky enough to get past the 6 month warranty and needed a new battery.
    '18 Ranger 1000 XP
    '14 RZR 1000 XP
  11. #40
    BPS
    BPS is offline
    (Robbie) Veteran Member BPS's Avatar
    May 2018
    Brady, Texas
    Everything
    75 times
    Back to my original post, I heard from the owners yesterday and they got one of there Rangers back from the dealer. The service manager told them that the alignment was off by about an inch. I can't imagine it being that far off but it's what they were told. Now for the best part, remember I said that they got ONE of their Rangers back. When they went to pick it up they asked the service manager when the other one would be ready. His reply, "oh, you have two of them here?".
