2015 900 busted front case (again)
This is a discussion on 2015 900 busted front case (again) within the Ranger Discussions forums, part of the Polaris Ranger Forums category; I busted the second front case on my 900 while in deep sticky mud.This latest differential was out of a 2016. I haven't taken it ...
Results 1 to 7 of 7
  • 1 Post By Woodsrider
Thread: 2015 900 busted front case (again)
    Starting Member MrCrowley's Avatar
    Jul 2017
    I busted the second front case on my 900 while in deep sticky mud.This latest differential was out of a 2016. I haven't taken it apart but i see its trying to spit the pinion out. Last time the ring and pinion both had broken teeth. Maybe bearing failure allowing the ring and pinion to separate? Regardless, i need another one. Is the Brutus still the best direct replacement? Should i get a billet case? I ride mostly muddy trails. Running only 30" Cryptids. No engine or clutch mods.
    2015 Ranger 900xp eps
    Highlifter 2" bracket lift
    Highlifter forward arched a-arms
    Highlifter high clearance rear a-arms
    Highlifter transmission
    Highlifter snorkel
    30" ITP Cryptid
    blah blah blan
    Veteran Member Woodsrider's Avatar
    Jul 2014
    86 times
    If you are doing proper maintenance it sounds like your setup and or riding style is exceeding the design of stock 900 front diff. There for you might need to upgrade to 1000 RZR diff are kits weld in and bolt in or a billet unit.
    pyromedic likes this.
    2014 XP 900 dyno jet fuel controller, SATV double wide rev chain, gear reduction (325 ACE), turf delete, front and rear winch, 30" ITP Blackwaters on tusk beadloc wheels, half doors with removable windows (home made), side rails cover system for dump bed, plastic roof, modified seizmik folding front windshield full rear window, longer gas shocks, full skid plate and rock sliders, front rack
    Jul 2017
    Quote Originally Posted by Woodsrider View Post
    i didnt know a bolt in one is available. Do you know where i can get one?
    Highlifter snorkel
    30" ITP Cryptid
    blah blah blan
    (Michael) 1000+ Member liftedpsd2010's Avatar
    Lake wales, Florida
    2017 Polaris ranger
    375 times
    Quote Originally Posted by MrCrowley View Post
    Highlifter sells a plate. I seen it the other day.
    Jul 2014
    86 times
    liftedpsd2010 likes this.
    Lake wales, Florida
    2017 Polaris ranger
    375 times
    That’s it, I meant to link it but forgot to come back.
    (Josh) Elite Member move's Avatar
    Mississippi
    11 times
    Easiest way not to break a front differential is to take it out of 4wd if you are going to attempt to reverse out of thick mud. I have busted countless front differentials and currently running a billet differential. Due to the tooth design, when in reverse the gears act like a mechanical wedge. It will either: break the case, crack teeth off, push the pinion out, destroy the pinion bearings or wallow out the pinion support. I have never broken a front differential in a forward gear.
    Here is a link to some of the latest carnage on my Instagram
    https://www.instagram.com/p/BuUc2NDH...ns_share_sheet
    2011 Polaris 800 Ranger Browning Edition
    Backwoods Armor arched control arms, SuperATV steering assembly, SuperATV axles, 29.5 OL2, STI HD1 14" wheels, Looney Tune Exhaust, Turf mode delete Transmission, Billet front diferential, Spal Fan
