Light Bar and Mounting
This is a discussion on Light Bar and Mounting within the Ranger Technical forums, part of the Polaris Ranger Forums category; Mornin' people! I want to mount a light bar on on the roof of my 2017 XP 900. Do these light bars just mount directly ...
Results 1 to 8 of 8
Thread: Light Bar and Mounting
    Starting Member Mudde's Avatar
    Mar 2017
    Mornin' people! I want to mount a light bar on on the roof of my 2017 XP 900. Do these light bars just mount directly to the plastic PO sport roof? With nothing to "stiffen" the mount? Seems like a low branch would knock it off. Ideas?
    Thanks for any help!
    Mudde
    2017 Ranger XP 900 Sage Green
    Polaris Poly Roof
    Polaris Lock and Ride Glass windshield
    Polaris Lock and Ride glass rear window
    Polaris Soft Doors
    Polaris heater
    Badlands 3500 lb winch / Synthetic Rope
    Seizmik ICOS gun holder
    Amazon El Cheapo manual windshield wiper
    Hornet cargo rack
    Denali plow & Mount
    SATV Winch Mount Front Bumper
    (Josh) Elite Member jobo2856's Avatar
    Aug 2016
    Rayne, Louisiana
    2016 900XP HL
    451 times
    This is what you need. I wouldn't drill through the roof.
    https://extrememetalproducts.com/i-2...-fit-cage.html
    2016 - 900XP EPS Highlifter Edition
    Mar 2017
    Thanks Jobo!. Problem is I want to use a 30" lightbar I already have. These mounts go from one side of the cage to the other; more like a 50" bar.
    Mudde
    Polaris Poly Roof
    Polaris Soft Doors
    Polaris heater
    Hornet cargo rack
    Denali plow & Mount
    (Joe) 1000+ Member jaybey's Avatar
    Nov 2005
    Tucson- Joe
    182 times
    Use the steel frame under the roof and drill thru the roof and the brace. Before fastening it down use some RTV or silicon to seal the holes. You would be better off getting a longer light for the roof. JMHO.
    Freedom has a taste only those who have fought for it will ever know.
    If guns are outlawed only outlaws will have guns. An armed society is a polite society.
    FEAR THE GOVERNMENT THAT WANTS TO TAKE AWAY YOUR GUNS!
    2015 Ranger 900 XP EPS, Polaris tip out windshield, glass rear window, Polaris canvas doors. 3600 lumen driving lights, TMH 20'' Dual Row High Power 126w Cree Light Bar 13000 Lumens
    , led driving lights for back up light, EZ turn signal kit, Garmin Montana 600, UMC ATV tool/storage box, Ricochet rock sliders, home made mud blockers, in bed mounted spare tire, Big Sky roof mount gun rack, Wolo Bad Boy air horn.
    PRC # 1164
    Life Member NRA & Golden Eagle Member
    Joe - Tucson, Arizona
    Aug 2016
    Rayne, Louisiana
    2016 900XP HL
    451 times
    I gotcha. I didn't know. I would definitely use some kinda backing plate. Maybe even two pieces of 1/8" flat bar and sandwich the plastic. Polaris roofs are notorious for cracking, flying off on the interstate, etc. I would definitely stiffen it up the best you can.
    Veteran Member TX 3400XL's Avatar
    Nov 2018
    72 times
    You will be fine using the flat bar as you described. If you are driving thru limbs it could damage light or roof but I dont drive thru limbs.
    It depends on your use of the machine..some do some extreme trail riding but honestly no matter how mounted on roof...limbs will damage either the light or roof.
    My roof has preformed recesses for light mounts and I added a small light bar and haven't had issue. I too can't use the roll bars as there encased by solid window frame.
    As an example...mine came with a grab handle leaning bar at the rear. Its mounted straight to roof and serves those sitting in bed mounted elevated seat system.
    It's been up there for 6 years....used to lean on for many hog hunts and have had zero issue. It's been used but not abused.
    Hell...the mounts for the roof are affixed to roof with rivets from factory. Just keep an eye on them....these are the reason people lose roofs towing at 70mph on highway. If one fails and roof begins to lift the results are ugly.
    (Tom) Veteran Member lexiontech's Avatar
    Feb 2018
    North Central North Dakota
    2017 Ranger 1000 EPS
    81 times
    I put a 22inch on mine when I got it, already had it that's why I used that size. I drilled through the plastic roof and the metal supports under it and bolted it down that way, it is plenty sturdy if you go through the metal supports and it also helps hold the roof on more securely when pulling it on an open trailer down the highway. I drilled another hole for the wiring and siliconed it and the bolts to keep the rain out.
    2017 Ranger 1000 EPS Bronze - 6500 miles, 760 hours
    Premium roof, electric window doors, sliding rear glass, tip out front glass, wiper/washer, heater
    72 inch steel snow plow
    Warn Winch
    Front brush guard
    Lock and Ride box topper
    Prospector Pro Tracks
    S3 HD Springs
    442 times
  1. Mounting a light bar on the Lock and Ride Roof
    By CYQXRGR in forum General Member Discussions
    Last Post: 01-12-2016, 10:12 PM
  2. Mounting Light Bar - ??????
    By StanMI in forum Ranger Discussions
    Last Post: 11-27-2014, 04:51 PM
  3. Mounting LED Light bar to roll cage question
    By tall_texan_65 in forum Ranger Technical
    Last Post: 07-04-2014, 08:17 AM
  4. Mounting LED Light Bar
    By Bark99 in forum Ranger XP 900 & 570 FS Discussions
    Last Post: 01-04-2014, 11:18 AM
  5. Mounting Light bar
    By Russ7172 in forum Mid-Size Rangers
    Last Post: 10-14-2013, 09:59 PM
