spark plug recomendations?
This is a discussion on spark plug recomendations? within the RZR Technical forums, part of the Polaris RZR Forums category; i having a hard time finding a cross reference for the Champion RC7YC3. little help please....
Results 1 to 10 of 13
Thread: spark plug recomendations?
    (Michael) Veteran Member MEGADESERTDIESEL's Avatar
    Jan 2008
    Mesa AZ
    "Drive fast and take chances"
    (Mike) 1000+ Member Myers's Avatar
    Jul 2007
    Indiana
    I can run a cross on it tomarrow at my shop. What other brand are you looking for? I think Thunderhawk Performance has some different heat ranges also. You may check with them. Any Napa or other auto parts dealer that sells Champion should be able to get them. I got a box of four from Napa, but they had to pick them up at the local wharehouse.
    Mike
    08 RZR Myers edition
    SPORTSMAN 500
    08 OUTLAW 90
    08 BLACK XP
    Jan 2008
    Mesa AZ
    not sure what brand to use. i would like something that is easily found over the counter. HPD has NGK iridium hotter plugs on their site but not stock replacement.
    Jul 2007
    Indiana
    I'll check it out in the morning and post back what other brands and part #'s it crosses to.
    Mike
    SPORTSMAN 500
    08 OUTLAW 90
    08 BLACK XP
    (tom) Veteran Member stroker08's Avatar
    Jan 2008
    freesoil mi.
    for whatever reason the stock champ., rc7yc3 is a very cold plug and some of the other mfg. don't make them that cold. fwiw......stroker08
    Jul 2007
    Indiana
    The only cross I could find was to an autolite 3922. That cross is only as acurate as my data system.
    Mike
    SPORTSMAN 500
    08 OUTLAW 90
    08 BLACK XP
    (Mark) PRC Sponsor guy48065's Avatar
    May 2007
    S.E. MI
    The Rzr is programmed to run rich and it appears to be "normal" for the plugs to be on the black side. Should I run a hotter plug on a stock engine or should I leave well enough alone and change plugs yearly?
    Romeo, MI
    http://tinyurl.com/8ltm8
    Now a 2-Rzr family!
    Jul 2007
    Indiana
    I personally stuck with the stock plugs, even on my modded motor. Its always better to run a plug thats a little cold compared to one that may be slightly to hot for the motor. JMO
    Mike
    SPORTSMAN 500
    08 OUTLAW 90
    08 BLACK XP
    (Leonard) 1000+ Member Sandblaster's Avatar
    Jun 2007
    Eugene, Oregon
    Why does the 2005 SP 800 take a different plug then the RZR 800? Any ideals?
    Sandblaster
    http://oohva.org
    Jul 2007
    Indiana
    Quote Originally Posted by Sandblaster
    I have no clue. Speculation would be that the head or compression ratio is different.????
    Mike
    SPORTSMAN 500
    08 OUTLAW 90
    08 BLACK XP
champion rc7yc3
champion rc7yc3 cross reference
champion rc7yc3 to ngk
cross reference for rc7yc spark plugs
polaris rzr 800 spark plug interchange
rc7yc3
rc7yc3 champion to ngk
rc7yc3 cross to ngk
rc7yc3 to ngk
