2011 Ranger 800 Crew Won't Start
This is a discussion on 2011 Ranger 800 Crew Won't Start within the Ranger Problems & Solutions forums, part of the Polaris Ranger Forums category; Brand new to the forums here. I've had my 800 crew for about 5-6 years now. We went for a ride over the weekend and ...
Results 1 to 6 of 6
  • 1 Post By alaskanparret
Thread: 2011 Ranger 800 Crew Won't Start
    Starting Member Zuule's Avatar
    May 2019
    I've had my 800 crew for about 5-6 years now. We went for a ride over the weekend and at our first stop it would not start back up. I put my foot on the brake, turned the key until all the lights and display turned on but when I went to actually start it, nothing happened. Turned key off, made sure I was in neutral with brake applied and tried again, nothing. I'm getting power (just had the battery tested). After a few minutes of monkeying around it finally started. This same thing happened once before a week prior when I was moving it out of my garage to do some work. It's very intermittent so I'm not sure how to test to see what's causing it. I've had so many issues with this thing in the last several years. Every time I go out it's something new.
    Any help on what could be causing this is greatly appreciated.
    (Court) Regular Member alaskanparret's Avatar
    Jun 2015
    South Anchorage, Alaska
    22 times
    Sounds possibly like the brake switch...they get dirty and cause this problem from time to time. If you look on the brake reservoir/master cylinder in the drivers side wheel well there should be a small electrical plug. Pull it off and clean it.
    Sent from my iPhone using Tapatalk Pro
    jungleman likes this.
    2014 Polaris Ranger 6x6
    27' Swamplites
    Caribbean
    2063 times
    Zuule, most likely the brake/starter interlock switch contacts like Court said. I would go there first. After that I would be checking/cleaning the battery connections and then the grounds .
    Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE. WHOA !
    2007 Polaris Ranger700 XP LE
    (Josh) Elite Member move's Avatar
    Mississippi
    11 times
    Yup, mine won't crank unless it see's brake pressure, just stepping on the pedal won't allow it to crank.
    2011 Polaris 800 Ranger Browning Edition
    Backwoods Armor arched control arms, SuperATV steering assembly, SuperATV axles, 29.5 OL2, STI HD1 14" wheels, Looney Tune Exhaust, Turf mode delete Transmission, Billet front diferential, Spal Fan
    1661 times
    IF it turns out that the brake interlock is OK it may be a relay.
    Polaris Windshield Wiper
    Trail Armor Skids
    Odyssey Battery
    SVI Traction Control
    SATV Power Steering
    Badland 3500# Winch
    KFI Winch Mount
    KFI 72" Snow Plow
    Sucool 48w LED back up lights
    Mississippi
    11 times
    Fuel injectors.
    I'm going to make a bold statement... If you own a 2011 800 and have yet to replace your fuel pump and injectors it's time to do so. I only have 1,300 miles on my Ranger and I've all ready been thru three fuel pick-up filters and one pump
