Help! '05 Ranger 500 carb engine with too much compression? - Page 9
This is a discussion on Help! '05 Ranger 500 carb engine with too much compression? within the Ranger Problems & Solutions forums, part of the Polaris Ranger Forums category; Haha wow. All this time....... Really the hose on there isn't even long enough to put anything in there. New top caps are freaking expensive. ...
Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 91
Like Tree35Likes
Thread: Help! '05 Ranger 500 carb engine with too much compression?
  1. #81
    Starting Member wrench's Avatar
    Jun 2019
    Really the hose on there isn't even long enough to put anything in there. New top caps are freaking expensive. I will put a vacuum cap on it.
    Still waiting on the secondary bumpers to get here.
    Thanks for all the help guys. Of course it was the simplest fix.
  2. #82
    BPS
    BPS is offline
    (Robbie) Veteran Member BPS's Avatar
    May 2018
    Brady, Texas
    Everything
    84 times
    Quote Originally Posted by wrench View Post
    What was there before the rebuild? Had to be something or it would of had the same problem.
  3. #83
    Jun 2019
    Beats me. Only thing nearby there when is the vent line that goes from the oil tank to that little deal under the motor mount. It has always been loose there until a couple days ago when I connected it to the air box.
    BPS
    BPS is offline
    May 2018
    Brady, Texas
    Everything
    84 times
    Something must have stuffed in there and during your disassembly/reassembly it fell out. I hate when stuff like that happens. Let us know how it's running after you get that cap.
  6. #85
    Jun 2019
    Will do sir.
  7. #86
    RJ is offline
    326 times
    Holy sheet! Never seen one like that either! No wonder the slide wouldn't open, talk about a huge vacuum leak. Should run like a champ now!
    27-11-14 Tusk Trilobites
    G5 tune
  8. #87
    BPS
    BPS is offline
    May 2018
    Brady, Texas
    Everything
    84 times
    Quote Originally Posted by RJ View Post
    I see them on some early 2000's and have never understood why they are there. They are always capped off and I've never seen a hose attached that terminates somewhere. Sometimes the underside of the seat will rub on the rubber cap and put a hole in it so check for clearance once it's all back together.
  9. #88
    442 times
    Had to put some putty on mine when it developed a crack on that barb. I ride some big chicks on mine. lol
    wrench likes this.
  10. #89
    Jun 2019
    She runs great now. Just trying to get the pilot screw adjusted correctly. I love how the manual says get engine warm (10 minutes of running before tuning) it is almost the only way to adjust the pilot screw is with a flat head bit from a drill because of the distance between the carb and the cylinder. On top of that every thing is freaking hot!
    Thanks for all the help and ideas guys.
    summermn and pyromedic like this.
  11. #90
    RJ is offline
    326 times
    Good deal Wrench! 2- 2 1/4 turns out should be close. Not easy to get to for sure. one of these work good for those tasks.
    https://www.ebay.com/itm/13-IN-1-Ext...edirect=mobile
    G5 tune
