Battery drain - Page 2
Battery drain
This is a discussion on Battery drain within the Ranger XP 1000 Discussions forums, part of the Polaris Ranger Forums category; 13.7 is what its charging at i believe....
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Like Tree6Likes
Thread: Battery drain
    RJ is offline
    326 times
    27-11-14 Tusk Trilobites
    G5 tune
    Starting Member Tcounty's Avatar
    Feb 2016
    9 times
    My charger says it has 13.7 in the battery. Cluster says 14. something when running.
    The battery drain problem isnít a problem anymore. I probably left the radio on or something. After I recharged the battery it hasnít dropped a bit.
    The problem now is the clock is resetting , this is not a battery problem.
    Feb 2016
    9 times
    I disconnected the negative side of the battery to try a reset. Iíll try it again in a bit a see what happens.
    Seems this is a common problem on the Generals and RZRs.
    Feb 2016
    9 times
    That worked. Left the negative side disconnected for an hour or so. Set the clock and it holding fine.
    RJ, summermn and Rangerwhit like this.
    442 times
    Hopefully not, but a slow short could easily show back up again if you hit the right bump. A wiser mechanic told me the best way to find one is to disconnect the negative terminal and lead, put a test light in series. If it lights, you have a short. Then start pulling fuses till the light goes out, narrowing down the location of such. Mind you, this was before all these computer module thing's.
    1661 times
    Quote Originally Posted by Rangerwhit View Post
    The problem with that method is that if you have an accessory, say a clock, that requires current all the time, your test light will light. In addition, some charging systems (automotive) with the voltage regulator built into the alternator will always show a current draw. I believe the mid 1980's GM products were like that (if memory serves me).
    You could still use that method but you need to remove the fuse from the circuit that runs the accessory or disconnect the alternator to eliminate the inherent continual draws, then perform your test. Unfortunately, you can't include the eliminated circuits in the test so if the problem lies there you miss it.
    Rangerwhit likes this.
    Polaris Windshield Wiper
    Trail Armor Skids
    Odyssey Battery
    SVI Traction Control
    SATV Power Steering
    Badland 3500# Winch
    KFI Winch Mount
    KFI 72" Snow Plow
    Sucool 48w LED back up lights
    442 times
    I suppose you could use the same approach paying attention to the brightness of the light, but an ammeter would be better. Seems better than chasing wires per say...
    yooper265 likes this.
