New Rear Differential for 2019 - Page 16
This is a discussion on New Rear Differential for 2019 within the General Member Discussions forums, part of the The RANGER STATION ~ Rangers and RZRs category; Originally Posted by Toxic-21 And Rear axles or modify the ones you already have. What modifications need to done to axles?...
Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 151 to 160 of 164
Like Tree140Likes
Thread: New Rear Differential for 2019
  1. #151
    Veteran Member Woodsrider's Avatar
    Jul 2014
    86 times
    Quote Originally Posted by Toxic-21 View Post
    2014 XP 900 dyno jet fuel controller, SATV double wide rev chain, gear reduction (325 ACE), turf delete, front and rear winch, 30" ITP Blackwaters on tusk beadloc wheels, half doors with removable windows (home made), side rails cover system for dump bed, plastic roof, modified seizmik folding front windshield full rear window, longer gas shocks, full skid plate and rock sliders, front rack
  2. #152
    Jul 2014
    86 times
    So does any one know what is different about the 2019 axle compared to prior 900 axle?
  3. #153
    (Rock) 1000+ Member rocknroll's Avatar
    between monkeys eyebrow and possum trot
    490 times
    What I have read is the spline on the inner cv is longer and the retaining ring is farther in so the old cv spline wont lock in. Maybe true, maybe not.
    But the axle shaft itself also has a different part number. I don't know what is different with that.
    Starting Member ProstarMaine's Avatar
    Oct 2018
    I would think that the axle update would only apply if you were replacing the 2017/2018 complete trans with the 2019. I believe when replacing the 2017/2018 planetary turf gear with the 2019 spider turf gear that the axle splines are not affected and you can reuse the same axles? Correct me if I'm wrong please.
    Thanks.
  6. #155
    Regular Member foster brooks's Avatar
    Oct 2015
    northern illinois
    7 times
    so will a 2019 transmission bolt right up in a 2018 ranger 1000?
    2018 Polaris Ranger 1000 red
    Polaris roof/ glass windshield/rear glass
    20" LED light bar
    Polaris 6000# winch
    66" glacier plow
    Windshield wiper
    turn signals/ horn kit
    visor stereo
    full doors
    heater
    heated seats
    side mirrors
    29" dirt commanders
  7. #156
    (Todd) PRC Sponsor Hunterworks's Avatar
    Jan 2012
    339 times
    Quote Originally Posted by foster brooks View Post
    There are better people to answer this than me but I think the only the Back Country Edition has the new one and I would think it would bolt up.
    Toxic on here knows more
    Todd Eldridge, Owner of Hunterworks
    www.hunterworks.com
    [email protected]
    601-771-0070
  8. #157
    Jul 2014
    86 times
    Quote Originally Posted by rocknroll View Post
    True retainer ring groove is deeper in carrier and old axles will not lock in.
  9. #158
    Oct 2015
    northern illinois
    7 times
    Quote Originally Posted by Woodsrider View Post
    so if you upgraded the transmission you have to buy the rear axles then? Would you need a clutch shaft alignment tool also for the ranger?
    Anyone swapped out a transmission on a 1000 ranger?
    20" LED light bar
    Polaris 6000# winch
    66" glacier plow
    Windshield wiper
    visor stereo
    full doors
    heater
    heated seats
    side mirrors
    29" dirt commanders
  10. #159
    Jul 2014
    86 times
    I would say yes to both questions. I also strongly recommend you have a service manual and a engine hoist as trans comes up the top it heavy and a tight fit through the frame. On my 900 I had to remove bolts holding front diff so that drive line comes off output splines remove the bed complete air intake and clutches. Also had to lift back of motor to extract the trans.
  11. #160
    Oct 2015
    northern illinois
    7 times
    thanks for the info, my trans starts to whine when I hit 25 mph, probably only a matter of time before it grenade's.
    20" LED light bar
    Polaris 6000# winch
    66" glacier plow
    Windshield wiper
    visor stereo
    full doors
    heater
    heated seats
    side mirrors
    29" dirt commanders
2019 polaris general changes
2019 polaris general rear differential
2019 polaris ranger new differential
new ranger locker rear diff
what differential in 2019 ranger
