Chevron Introduces Techron Protection Plus Fuel Treatment For Powersports - Page 2
This is a discussion on Chevron Introduces Techron Protection Plus Fuel Treatment For Powersports within the General Member Discussions forums, part of the The RANGER STATION ~ Rangers and RZRs category; I use red stabil in anything 2 stroke....
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree18Likes
Thread: Chevron Introduces Techron Protection Plus Fuel Treatment For Powersports
    439 times
    1628 times
    Quote Originally Posted by Rangerwhit View Post
    Most 2 stroke oils today have stabilizer in them. Stihl, Husqvarna, Toro, Poulan, Echo, etc., and even some aftermarket oils like Opti 2, Power Care (Home Depot). I'm not sure what additional protection you are getting by using StaBil in your 2 stroke engines if the oil already has it in it.
    summermn likes this.
    Polaris Windshield Wiper
    Trail Armor Skids
    Odyssey Battery
    SVI Traction Control
    SATV Power Steering
    Badland 3500# Winch
    KFI Winch Mount
    KFI 72" Snow Plow
    Sucool 48w LED back up lights
    1226 times
    I've bought Stabil 360* last year and ran it in my ranger with ethanol fuel. It keeps the gas from separating if I remember right.
    rocknroll likes this.
    2014 900 XP EPS.....28"Mongrels- forward 'A'arms- Rhino axels-MMA lift-Duraclutch-Viper winch-canvas doors-DragonFire doors-Elka stage2 shocks- Gilomen tune and other add'ons
    "Happiness isn't having everything you want, its wanting everything you have"
    Veteran Member TX 3400XL's Avatar
    Nov 2018
    71 times
    I've put stabil red in my cans before I fill them everytime for years....maybe i should a been using the stabil360...I put marine stabilizer treatment I think is etec...its expensive whatever it is but marine mechanic said it was what I should use.
    Generator is gummed up AGAIN....chain saws gummed up. It's hard to run everything every few weeks or at least to remember to do so. I've rebuild more carbs in last year and wearing me out.
    2 boats, 2 tractors, old pit bike, go kart, Bobcat UTV, zero turn mower, 2 trucks, chain saws, weed eater, 2 blowers, pressure washer and a generator....some are diesel, 2 stroke and 4 stroke. Whole thing would be simple if we got real gasoline instead of cream of corn!
    pyromedic likes this.
    (ron) Elite Member wgarcar1's Avatar
    Jun 2016
    vero beach, Florida
    230 times
    If you add sta-bil or any of the others to your tanks just do yourself a favor and check the fuel lines every year, they can get soft and burst when unexpected.
    Same goes for generators etc.
    Sent from my SM-G950U using Tapatalk
    2018 ranger 900 XP full size. from sky motorsports of Lake wales fl
    KOLPIN 6.0 gun boot+bed mount for the AR. from kolpin.com
    KOLPIN KXP Rhino Grip XL Double Set for Polaris Ranger Lock N Ride UTV 21517
    Multi-Vent front Shield W/HardCoat (77-9525) and rear(77-9600). from utvheadquarters.com
    heavy duty aluminum roof. from Marty at whomoto.com
    Hornet R-3024 Ranger Hi Lift UTV Jack and mount. from ebay
    20" LED green Light Bar/120 Watts/Waterproof. from TexStar Lighting 936-337-4333
    6" round white LED lights under bed. from ebay
    4500 lb KFI front winch. from ebay
    ITP MUDLIGHT XL tires ( 25 x 11-12; 489 on fronts and 25 x 12-12; 489 on rears) no rubbing from ebay
    POLARIS brush guard. from polaris
    171 times
    Bought a generator last fall and it says to use a gas stabilizer with every fill. I will stick with either Stabil or Seafoam.
    When I did the service on the all the small engine products on the fire department I would change out the fuel every month unless it had been used enough to use a full tank. In the 13 years the only issue we had was operator error. Got to love when the chief(not FMO trained) takes off with a Honda fan unit and can't get it to run and I go over and turn on the switch to get it to run with a crowd watching. Same chief that took off with a tanker to a mutual aid fire and it had no water as it had been taken out of service to repair the pump seals.
    1628 times
    Quote Originally Posted by wgarcar1 View Post
    I believe ethanol affects fuel lines and rubber more than StaBil or any other fuel stabilizer. In my experience StaBil has never damaged or softened my fuel lines.
    Here's an interesting article aimed at boaters but which applies to any vehicle using ethanol:
    https://www.crisfield.com/gold/Ethan...eb%20ready.pdf
    And another:
    https://www.onallcylinders.com/2016/...line-material/
    wgarcar1 and chrismorlo like this.
    Trail Armor Skids
    Odyssey Battery
    SATV Power Steering
    Badland 3500# Winch
    KFI Winch Mount
    KFI 72" Snow Plow
    1628 times
    Just remember, when you're the Chief you don't have to be good, you just have to look good. We had several on our department promoted based upon gender or ethnicity who never had the ability to do the job. Some of the gender promotions could never start a K-12, blower fan or generator.
    Trail Armor Skids
    Odyssey Battery
    SATV Power Steering
    Badland 3500# Winch
    KFI Winch Mount
    KFI 72" Snow Plow
    1628 times
    Quote Originally Posted by stainlessman View Post
    From the StaBil web site:
    https://www.goldeagle.com/tips-tools...-bil-products/
    and:
    https://www.goldeagle.com/tips-tools...yths-debunked/
    See the last paragraph under Myth#3 for confirmation that StaBil 360 keeps fuel fresh for up to 12 months.
    Trail Armor Skids
    Odyssey Battery
    SATV Power Steering
    Badland 3500# Winch
    KFI Winch Mount
    KFI 72" Snow Plow
