I have an 08 Ranger Crew 700 efi. Thing drives great but started last summer with the hard to start and idle problem. Have to put one foot on the brake and one on the gas pedal a bit to get it started. I did the following:
1. Changed the plugs last year, helped but no fix.
2. Read the forums about setting the TPS and I ordered the harness kit and tool to adjust the D screw.
3. Go to set the TPS voltage and the sucker reads 3.8 - 4.3 volts......YES, I set the multimeter just like the directions said to 20 dcv. I even tried another meter. I tried adjusting the base voltage as well by loosening the screw on the TPS sensor and moved it from all the way one way to the other........no drastic change, again from about 3.8 - 4.3 not .5??. I've read where this should ultimately be about .660 or so on this model.
4. I took the throttle body off both hoses so I could get to it easy and cleaned it good inside with carb cleaner. Verified the butterfly was in fully closed position.
5. Took the Tbap sensor out and carefully cleaned it with some CRC electrical cleaner with a Qtip. Cleaned the inside of the rubber boot it fits in.
6. So I gave up and adjusted the TPS base and the D screw til I could get approx. 1150 rpms at idle but it's running real rich at an idle. It will start now without a lot of trouble but it's just not right.
7. One thing I haven't checked is for codes since I just learned how to do that tonight after reading and my machine is at the lake house.
I keep thinking after reading all of these posts about the Tbap wiring harness problems and maybe even a TPS wiring problem but doesn't this sound like a bad TPS sensor??? I don't mind spending the money to fix it but I hate to replace high dollar stuff and it's not the problem.
