I'm going to be kind of all over with this one so bare with me;
I finally got my front axle out of the hub, little heat, a 60ton press, some luck and it came apart without breaking anything...woo-hoo! what a bitch, bearing split and half the inner race was froze to the hub had to torch it off, sometimes you get lucky and catch problems before they become devastating.
Rebuilt my clutch had a bad bearing, rollers and weights were good and while spinning the spider off lost one of the buttons, yeah I know it's got to be there somewhere, maybe with the socket I lost last year, anyways replaced the bearing, spring and buttons but now they are a little tight at the top of the tower, should I be concerned or will they seat in?
Now for electrical, going to put in 2 new batteries but will do so without an isolator, need the extra power for my sprayer, would it be better to run separate cables to the power block or can I make new cables tying both together then to the block or does it make any difference.....or sense?
