I havent noticed the light coming on but I will check that today along with disconnecting the solenoid.Normal mode is 2wd with the rear locked. When the solenoid operates it unlocks the rear and you have an open differential but both wheels still pull.
Does the turf mode light come on when it kicks out of 2wd?
Are your rear tires aired up to the same pressure and are they the same height?
