1 - 13 of 13 Posts
Being cheap like I am I decided to build my own doors and bumper over the past couple of week. The doors cost roughly $120 for the pair and they are made of 3/4" DOM tubing, 1/8" ABS plastic and ebay slam latches. Sorry I forgot alot of the pictures I didnt think about it until it was too late. Now that its finally stopped raining I'll get some more pics.
Rear bumper 1-3/4" DOM tubing
Super Moderator
Pit has some Skills!!
Both of those look fantastic, well done.
Reactions: zmnypit
Nice! Could you post some closeup shots of the latches, hinges and the attachment points. I may try and tackle this as my next project.
The latches I used: Pro Armor Front Suicide Door Slam Latch POLARIS RANGER RZR 4 800 2010 P081291 | eBay
I took the supplied brackets cut them then flatten using a hammer/anvil. Cut a notch out then welded to the cross tube. The handle I made free hand and the cable is bicycle brake cable from walmart. Just cut it to length and done. The hinges is 3/8" bar stock from lowes and the tube is 3/8" ID also from Lowes. I just went in and found a decent size that fit together nicely.
Nicely done!:excitement:
Discussion Starter #7
Not sure honestly. The brackets are 3/4" dom cut to fit where the bed hinges and then two pieces of flat bar that bolts to the bed just under the tailgate.
Discussion Starter #9
ABS plastic may have been the wrong idea. It doesn't appear to play well with the sun as I've already got some warping. May have to switch to sheet metal or more rivets.
Just a thought. What if you slot some of the mounting holes in the ABS plastic to give it room to grow? Then "back off" the tightness of the nuts and bolts so it fits a little more loosely. If you are concerned about it rattling, you could sandwich some self adhesive felt in between the ABS and nuts and bolts. Might be worth a try, rather than starting over with metal. Or, let the doors get nice and hot in the sun, slot the holes and then tighten them down.
Discussion Starter #11
They actually shrunk back down and was fine the next morning. Went riding sat all day and I must say its a huge improvement over no doors. Only negative side is the notorious cab heat. Every once in awhile it would get warm. I'm thinking of adding some kind of sliding vent to them next
Nice work, Pit!
1 - 13 of 13 Posts
