The plow is going to block "some" air flow, but most people don't have that issue, so I'd make sure that the radiator is perfectly clean. I've seen MANY overheating issues caused by a partially clogged radiator and that would definitely be the first thing I'd check.
Your location isn't listed, but I assume the weather was cold if you're running the plow?
