Hello everyone newbie here from Arkansas. I have a 6x6 that has been setting in the garage that we dont use much. Well we are now a manufacturer and dealer or PAS lights and we want to make something a little different and thought why not just build this. Well what i am wanting to do is lift it, some wheels and tires and rear mounted seats, some audio and lights.
Now i do know that the front looks like every other ranger but not sure if they are the same.
The back axle is hard mounted to a pivot type swing arm with the same type of shock coil over.
The second axle uses what looks like the same type of independent suspension on a normal 4x4 ranger using the same type of coil over shock spring.
I am not looking for anything huge 3-4 inches maybe. I would like to move the rear axles back and thing i could with moving all the mounting locations back for the axle or building some sort of extension where it picots and only moving the upper shock/ spring mount. I think you could possible lift the whole thing by making new upper mounts for the strut/springs.
Has anyone ever done anything like this. I know i have seen some custom lifts on some newer models
Any help would be great.
