Just recently my ranger will not drive in 2wd, only in 4wd. Do you think it is the right rear wheel axle, the rear diff or the trans? occasionally, it will go in 2wd but only for a short period, then I have to shift into 4wd.
You most likely have stripped axle splines, stripped differential inner hub splines or both. They don't make the axles anymore but they can still be found with some searching.
