I've a 2006 Ranger XP 700. (Build date 12/2005 VIN digit 10 is "6" for 2006 model year.) Possible multiple problems and/or causes? More than one year ago it was scheduled for a top end rebuild with a local mechanic. On the day I was to deliver it, it suddenly wouldn't start. After extensive trouble shooting we determined the ECM (under the hood) was faulty. Module Masters confirmed it was toast, multiple problems including a cracked board and several bad connections/components, couldn't repair it, so I waited almost a year for Partzilla to deliver an OEM ECM. (Thanks to COVID, they tell me...)
Jump ahead one year...when new ECM was installed, the buggy started up perfectly...but would not accelerate. Simply touching the throttle caused the engine to die immediately. Mechanic did the top end, replaced fuel pump, drained tank and added fresh fuel, checked and/or replaced TPS, TBAP, still won't do anything but idle. If the gas pedal is touched or the throttle plate cam opened by hand just a fraction of a degree...she quits immediately.
I've personally continuity checked every wire from TPS, TBAP (TMAP?) and CPS to ECU computer under the seat...no opens. I've disconnected power for several minutes and confirmed there are no stored and no new codes at all, just a code "61." I removed the throttle body, cleaned it, set TPS according to the manual (0.528 volts with "D" screw backed out, then adjusted to 0.660 volts at idle position) Absolutely no improvement...in fact, I think I have a rather low idle rpm now, and it will stall if allowed to idle for more than 2-3 minutes. Fuel pressure is rock steady at 40, and I checked it with a real fuel pressure tester.
Local mechanics are great for general work, but nobody here can seem to do any diagnostic work. I've noted several threads with similar problems, but no one ever seems to fix the situation, or they simply never POST about their solution. Any ideas out there? Gracias in advance...
