Need a little help. I have a 2006 ranger xp 700 little back story it was in a flood back in 8/17/2021. after the flood completely went tru and repalced all fluids and filters.
ran fine till summer then it quit moving would idle fine but touch the pedal and die. Have changed injectors, harnesses, tps, crank sensor, plugs, wires and filters and fluids again.
Still nothing. i have been told that the module is the problem #4011370 but i have yet to find one. fuel pressure is 40# and have set the tps sensor and tried everthing.. so any help at this point would be greatly appreciated. i will run and rev up off of starting fluid, i have traced the harness the best i can and looked for a problem but so far nothing.
