Heath................."is this correct or should it always be at 12 volts?".................It is correct.
" where I set it with the throttle cable adjustment"................The adjuster is for setting the proper slack in the cable(1/16") not a specific idle RPM. Without that slack your idle will be all over the place.The TPS is the main component for controlling the idle. base setting .528 and D screw air setting .710.
If the TBAP connector/harness is the original I'd say you probably have a wire break at the underside at or very near the connection .. www.otbpowersports.com
I would check the throttle body adapter for cracking at the flange where it bolts to the head if you have never replaced it since it was new it is almost certain that it is bad.
That should get you going in the right direction.
