After much time spent troubleshooting I am in need of assistance. I can not get this ranger started 😫. Here are my work done and troubleshooting work I did to it already.
Engine turns over but no start
Fuel pressure 40psi+ and holds
Compression 180psi and holds
Has spark
Crank sensor .552ohms @ 80 degrees f
Fuel injector 14.2 ohms
Tps sensor voltage @ .626
Fuel injector pigtail. Harness checked continuity
Tps harness continuity
Tbap harness continuity
Replace that pigtail
Stator harness continuity
Symptoms no start and backfires through air intake
Plz help I can not get this bad boy to start plz help guys I don't know what else to check
Has spark
