purchased a used 2007 Ranger wondering what is normal for oil consumption and what is a good suggested oil
seems like I'm using a lot considering it only holds a couple quarts
Thanx Revy Lou
When I sold my '06, it had about 600 hours on it and used ZERO oil, so any oil consumption is a concern. As you mentioned, it only holds 2 quarts, so it doesn't take much to run one dry and blow the engine. I changed my oil every 50 hours and the oil level at time to change was always the same as when I filled it. If you're using more than a pint in 50 hours, I'd start looking at a rebuild (assuming that it isn't leaking out somewhere).
I never changed mine, and have never heard anyone else mention changing theirs, so I don't think so. I'm not sure that they actually have a PVC valve.....just a breather.
