My 2008 rzr 800 is shifting very hard and now is bogging at full throttle
OK, better information, I quoted you so I can use your information as a reference. Top speed 30 mph - look to your fuel pump - check fuel pressure at idle and as fast as it will go - if at any time fuel pressure is below 39 psi replace the fuel pump. Jerry has given you good places to look for the creeping, once that is fixed it should cure the difficulty shifting. Now one other major issue with the 2008 machines is the air intake, you need to check to see if you have the intake fix on your machine. Look at the air filter box cover. If it has only two latches on it you most likely don't have the fix installed, if it has three latches you have at least part of the fix. The second thing to check is the large intake line between the filter and throttle body, if it doesn't have any pleats in it then you don't have the fix and have likely ingested dust into your engine and may very need to have at least a top end rebuild if not a complete overhaul. Before you hit the panic button make sure that the previous owner hasn't installed an aftermarket intake system onto your machine. Compare what you have to either your owner's manual or to a 2008 service manual. If you have an aftermarket intake check the filter to make sure it isn't one of those oiled foam filters, if it is, again you probably have a dusted engine needing the repairs that I outlined previously, if it's a pleated paper filter then you are probably OK. (I'm assuming you purchased the machine used from some of the comments you made, I apologize if I'm wrong.) I know I posted allot of information take your time and you'll get through it all.It's all stock as far as I know. It idles fine and seems to run fine until I'd say half throttle any more then that it doesn't seem to wanna open up maybe 30 mph max. Sometimes the check engine light comes on and it run rougher to. And yes it moves with no throttle. It idles down to 1100 rpm. It back fires periodically to
Thanks for the help
You might have an issue with the rectifier/voltage regulator. That was a problem on the first generation RZR's and they came out with a kit that relocates it (up near the radiator, if I remember correctly) so it doesn't get hot and cause that problem.Ok thanks guys another thing I noticed if I have headlights and it has another set of lights on front bumper with those on as well and using winch for plowing it seems to act up a lot quicker then if those are off could something electrical be overheating
