2009 700 hd running rough
1653 Views 14 Replies 6 Participants Last post by  Toxic-21
Ok I'm scratching my head here. So I went out ice fishing yesterday alot of water on the ice. Ran fine all day. Woke up this morning and it had no power and ran rough.
1 plugs looked a bit lean when I pulled them
2 sprayed carb clean around the throttle body and boot to check for cracks and so called worn out throttle body ( dealer told me to ) no rpm change .so ok I guess.
3 checked wiring to tps no broken wires but the connecter looks burnt .can't post pics so no help to you guys .
4.t bap un plugged and found a wire that (seamed) to be broke in the coating but not sure. Pulled lightly and it stretched and broke. Thought it was suppose to run rich with wire broke but seems lean.
5 run the motor with the t bap unplugged and it's really rich
6 throttle body looks good in the inside seals good closes tight
7 scratching my head some more
8 idk what to think
1 - 15 of 15 Posts
Would it run rough with one wire broke and rich with the whole thing unplugged ?
I'd start by fixing the TBAP wires. Get the one from OTB Powersports.....it has thicker wires than OEM and is cheaper.
It "should" default to a rich setting when there's any sort of malfunction with the TBAP, but who knows.
What would cause it to starve for fuel or act like the choke is on but not run rich
Limp mode?
Replace the Tbap harness and I bet it will run fine again. They were notorious for breaking into at the connection to the TBAP and back where Polaris zip tied them too tight and they worn through the wiring.
I don't think it was initially the t bap. NO codes were shown. Codes showed up after I removed the harness and possibly broke the wire. Now I have codes. And it's running really rich. It has to be a wiring problem it ran fine till it got wet and froze.
Broken Tbap wires can make it run real rich.
A weak or failing fuel pump will do that, and that's also not an uncommon......but I'd fix the TBAP wires before chasing another issue that might be nonexistent.
Ok. New harness came in and installed it. Starts and stays running now. Took it for a couple mile ride down the road. Seems boggy. The idle fluctuates between 1250 and 1150. Doesn't seem like it's idling smooth Sounds like it has hiccups. Doesn't seem to be running rich anymore. Tps is set where it's supposed to be also. What should my next step be?
And no codes
It sounds like the TPS. You state that it is set, what is it set at?
Has anyone adjusted the idle screw?
Is the unit getting hot?
.660 and the idle screw looks to never been touched its still has the sealing on it .im not throwing a temp light or over heating as for getting hot but the valve cover seems to be very hot but what am i looking for getting hot .im gonna pull my plugs in the morning and look and see if its lean or not i rodded on it pretty good tonight out on the snowy trails.
The 09' had cooling fan issue (OEM), curious if the unit had defaulted to limp mode, since you stated, it seemed to be bogged down.
But then you stated, you were not getting any codes.
1 - 15 of 15 Posts
