1 - 18 of 18 Posts
Been experiencing progressively worse performance and idling, until I decided to look today and found this hose was somehow ripped or melted off.. What part do I need to replace this?
Automotive tire Motor vehicle Gas Engineering Machine
That's it.. Thanks. Is it normal for these to split apart like this? I did change the TBAP harness a couple weeks ago and wasn't sure if that could have anything to do with it.
The 700s and 800s will split like that over time. The 900s are know for leaking where they mate to the cylinder head but don't usually split.
Kinda think a compression test may be in order.
James, that TB adapter appears to have been going bad for a while. Get a can of carb cleaner and take that throttle body off and clean it and check the airbox for oil stained filter...and>>>>>>>>>check the air box boot for a crack/tear right around where the TBAP sensor goes in. Clean the TBAP sensor with the carb cleaner also... Then do a compression test as RJ said. Both plugs out........wide open throttle and look for 150 psi..
Discussion Starter · #8 ·
Got the replacement throttle body adapter in and it's running just about as good as it was - but hope we can make it better.. Need to pick up some carb cleaner so I can do as you suggest, but what adapter do I need for this to do a compression test?
Watch Analog watch Motor vehicle Gauge Font
James, I believe you will need a 14mm adapter for tthe compression tester..
Discussion Starter · #10 ·
OK.. Thank you. I'll probably just pick up a new compression test kit, looks like they aren't very expensive. And maybe a couple deep sockets.. I just tried a 14mm on spark plug and it's too small.. and 15, 16, and 17 are missing :mad:. Most of these tools were inherited from my dad when he passed. I did not inherit his mechanic skills or his (dis)organizational preferences.. Checked the service manual, it helpfully just says "2. Remove spark plugs".
My CT came from HARBOR FREIGHT and included ALL sizes ......about 20 bucks....
Discussion Starter · #15 ·
Update: Disconnected TBAP sensor and removed the bolt but it just spins around, couldn't figure out how to remove in order to clean it.. No cracks or tears. Looks like a previous owner may have already replaced this boot, it feels newer and more flexible than the rest.
Attempted a compression test, after about 5 cranks on the one side it was reading 125. But, then it started popping.. I'm probably not doing something right.
Just to be sure I'm doing the test correctly - am I removing both plugs at the same time, then connecting the tester to each cylinder and cranking 5-8 times, or just remove one plug at a time? Do I need to disable the fuel injectors somehow?
Also - any tips on accessing the TBAP sensor? I couldn't get it separated from the hose/adapter? Jman, tell me how many cases of patron to send your way.........
James, BOTH plugs out ..........WIDE OPEN THROTTLE .........spin about the same number of revolutions per .... I donot disable the injectors but you could if you want to. It would be nice if the motor was warm but that is tough if the engine wont start .. 1 fifth of PATRON is adequate ..
Unbolt the TBAP I think it is a 3/8 wrench and PULL out the sensor........PULL HARD...
Discussion Starter · #18 ·
OK.. so I need not be concerned about the micro explosion noises I'm hearing while running the test? That's why I stopped working on it a few days ago.. Didn't want to damage it further.
We know at least one cylinder is only reaching 125psi then.
1 - 18 of 18 Posts
