1 - 3 of 3 Posts
My 2009 Ranger won’t go into 4wd. I have changed out the front gearbox fluid. Is there something else I should check before taking it to the shop?
11ish volts DC going into the case ?
Remember .if the back wheels don't lose traction, the front gearcase will not engage..
Not sure if models vary but this came up before...I just had my Bobcat in the air (same setup as polaris crew). When in turf the rr spun..when 2wd both rears spin and when in 4x4 all 4 spun...it was on stands.
As mentioned, I would check wires and voltage.
1 - 3 of 3 Posts
