Good afternoon,
Last October I bought a Ranger that used to belong to my dad. The guy who owned it between dad and I only put 15 hours on it so I thought it would still be in great shape. Wish I could go back and do that day over again. I've been chasing a code 51 and No. 1 cylinder flooding problem since February. I believe I have reached the limits of my mechanical knowledge and skill so I'm searching for some suggestions. Last hunting season I smelled raw fuel a few times while riding to hunting spots. It seemed to run fine so I thought I was picking up on a problem that didn't really exist. Then one day it shut down one cylinder completely and I got a code 51. I read about common problems with the t-bap wiring so I replaced it with an OTB unit. When that didn't fix the problem I took it to a local dealership who told me it was a bad injector so I bought a set and put them in. That didn't fix the problem so I swapped sides with the injectors, which didn't fix it either. Then I swapped sides with injector wiring harnesses, still the same. I tried to find a local parts store who had a tool to test fuel pressure but nobody had what I needed. I put in new spark plugs, checked to make sure I didn't have a broken wire in the tps, double checked my t-bap fix, checked for broken wires from the injector plug all the way to the ECU plug with multimeter, then purchased a new ECU. None of that fixed it either. 30 minutes ago the mailman delivered new spark plug wires and air filter. While I was waiting on those to arrive I cleaned the t-Bap sensor itself. I don't want to just keep throwing money at it but I'm not sure what to do now. Any ideas?
Out of curiosity, if the voltage on the tps sensor was out of spec, or the fuel pump was going bad wouldn't that affect both cylinders instead of just one? I appreciate your time.
