1 - 2 of 2 Posts
Im checking voltage to my tps and the power supply coming to the tps is only 3.30v. I checked it coming out the the ecm and its 3.30v there as well. Is 3.30v correct?
Moderator
C, the 2005-2009 700's require 5 volts per the Service manual. Many reports of newer 800 models running normally with 3.3-3.6 vdc..
2011 800's are notorius for bad IAC.....TBAP & TPS sensor wires.. Chaffed.....wire broken inside the outer insulation etc..
Reactions: gmck154x4
1 - 2 of 2 Posts
