Hello everyone, I'm new to Rangers, and have one that won't currently start. When I first got it, it had a bad brake sensor, so I put some wire in the harness side of it and got it to start cranking. Now that its cranking, its not wanting to fire. It will run on a shot of ether. I have fuel in the rail, although I'm not sure on the pressure at the moment, (buying a pressure gauge right now). I pulled the injectors, and they are spraying, probably shot fuel a foot or so in the air. I checked for spark at the plug, and I have spark. Battery is fine as well.
When I pulled the plug, I don't recall seeing gas on the plug although I'm pretty sure it was cranked enough that it should have gas on it. Just got it to my house, going to check this again.
I only have two codes, O520270-5, and I520269-5. I found two broken wires to the IAC, when I held them back in place I could hear the diaphragm moving, but still no start.
Any advice on what to check? I feel like I should have air, fuel and fire so it's confusing why it doesn't act like it wants to hit. Any help is appreciated, and thanks in advance.
