2011 Ranger 800XP Won't Start
14706 Views 23 Replies 6 Participants Last post by  RangerXpDriver
Went to use my Ranger today only to discover it will not start. The engine cranks over normal but there is no attempt at starting. It was running normal when I parked it a couple of days back.
I am sure that it could be many things but would like to ask you guys for a few more common failure points to start checking.
21 - 24 of 24 Posts
I had put fuel in it about 2-3 weeks before all of this started and just used it on short trips deer hunting on the farm. The ranger sat for about a week when the no start showed up. Anyway, I checked again this evening and it started normal for the second day in a row. I believe this problem is resolved. Thanks to all that replied.
I only run no ethanol in mine since it sits for long periods sometimes while I am away at work. I learned my lesson a few years back with ethanol fuel in my boat, drove me crazy for a year until I emptied and flushed my tank.
2014 Polaris Ranger 570 crew
I would be curious to know ,if after one these cranking sessions, if the plugs are wet.While your down there checking, removing the CPS and and cleaning it would be a good idea. Gunk/filings etc can build up and block the signal.
I have been having similar issues with my 570. It has been fouling plugs every 2-3 times I drive it. It only has 77 hours on it. The have changed the map sensor it helped get cranked but won't run right. Just wondering if you ever found the exact problem.
I am now certain that my problem was bad fuel. Since draining and replacing the fuel, I have had no more problems.
Reactions: 1
21 - 24 of 24 Posts
