I got a 2012 800 Crew a few weeks back. Had to do a bunch of repairs on it like wheel bearings, CV axles, brake pads... that kind of stuff. Previous owner had let it sit for a couple years because he said the trans was gone. I was able to get it started and drive it on the trailer. Finally get everything back together and drove it around for maybe 5 miles. Turned it off and tried to start later and it will not start. Engine turns over just fine, but it will not start.
Sometimes it will hit a little, but that is all I get. The error code that it is showing is 636-2 (crankshaft position sensor).
Here is what I have done.
1.Per the service manual I checked the resistance of the CPS sensor. Reading is 600 Ohms between yellow and white wire. Manual gives it to be 560 +/- 10% (504 to 616). I assume the sensor is good.
2. The CPS wire is a twisted pair black and white wire with a brown shield wire going between the CPS connector and the ECM so it is easy to find the wire in the loom at the ECM plug. I checked the black and white wire for continuity between the CPS plug and back probing the ECM plug (unplugged from ECM). Reading for both was 0.1- 0.2 ohm. No broken wire.
3, Checked for short between black and white wire and it was open. No short.
4. Pulled off fuel line on the rail. When I turn on the key, the fuel pump cycles for a few seconds. Got good fuel flow, but did not check the pressure. When I release the fuel line on the rail, there is pressure there because a small amount of fuel squirts out.
5. I pulled out plug and spun over engine. Plug is firing good.
Only other thing I have thought it might be could be is engine timing. Maybe the flywheel has sheared the flywheel key and it is no longer in correct time.
Question:
1. If CPS sensor passes Ohm test, what is the chance that it is actually bad?
2. When the engine is turning over, if I change the display to show RPM, it shows the RPM as it is turning over. Does this alone not indicate the that CPS sensor and wiring are good?
3. What am I missing?
Question:
