1 - 3 of 3 Posts
Starting problem: Turning the ignition switch (turned full right to stop) starting won't engage (nothing happens). Battery is fully charged. Panel lights come on. replaced the brake senor (new) replaced the solenoid (new) replaced the switch (new) cleaned + - electrical contacts from battery. At a dead stop//// Please help
"Battery is fully charged. "
Hock, it sounds like the battery is shot.........Volts but no amps.. Get it load tested for free @ Autozone...
Hello Jungleman, Thanks for the reply with my 800 starting and running problem. I load tested the battery. Its in good shape. I can short across the solenoid and turn the engage the starter turning over the engine. The engine won't start jumping the solenoid. I checked the hot wire to the brake senors with oms check. It was good. Stay Healthy
1 - 3 of 3 Posts
