Hi guys. I've been over heating. I use the machine for mowing with a pull behind mower mostly. I'm getting the type of over heat where it gets hot, cools to 194 with the fan and eventually each time it comes up it gets hotter and hotter. I've red lighted a couple times. If the thermostat sticks closed will you see a very fast increase in temps when the engine is already hot? The fan seems to come on and off fine at 204 and 195.
I swapped the OEM clutch for a R series duraclutch recently. The over heating started after the new clutch. The new clutch is needing more RPM to get engagement.
Can anyone tell me, because I forget, about how fast are you going on flat ground in low gear at 3300~3500 RPM? If I remember I was about 15mph.
Now I think its about 5 to 7mph.
I am unsure if I am over heating because of the higher RPM now or a combination of other things common of a machine of this vintage. Or a combination of all the above.
I see the fuel is a little lean on the plugs but not excessively. Could be from a hot engine and fuel line proximity?
I will be pressure checking the radiator and coolant system.
I will pressure check the fuel pump as well.
I'll get back to you with that info this weekend.
But before I bring the ranger into the shop,
Since I will be changing the coolant, as it's probably old, I didn't know if I should go ahead and order a water pump impeller?
Change the thermostat regardless if it currently tests ok?
Seems like the worst case scenario is a bad head gasket, but seems its not entirely common cause.
Is there anything in the coolant system that you might change out because of the effort and cost involved in draining the system? Hoping not to drain and bleed the system twice.....
Any thoughts are much appreciated.
Correy
Correy
