I recently acquired a 2012 Ranger Crew 800 (EPS). It has a few issues mainly from the PO just not taking care of it and it has been sitting for a year or so. One of the main problems with it is play in the steering. I found the lower steering shaft has worn out u-joints (Item 38, 1823995). I thought that I could just replace the u-joints for a few bucks.... but NOPE! Polaris decided to make the u-joints non-serviceable and force you to buy their overpriced product. Now I have to replace the entire linkage at a tune of $200. What a total POS this is. The u-joints are stacked in place rather than using a c-clip. GARBAGE.
Next item is the Parking Brake. It doesn't work because the pads are totally worn out. I ordered a new set of pads and after I got the caliper off, I see that the pads are also non-serviceable. Polaris now wants you to buy a complete caliper assembly (1911785) at around $120. I did a little searching and it appears that models built before 10/10/2011 have serviceable calipers (1911594). Now I am on the search for one of these used and I will just put in my new pads.
Whoever puts a non serviceable brake caliper on anything needs to be fired!
