I spent hours on the forums reading all kinds of suggestions and tips to find and address the idle surge that was causing me havoc trying to get the rig in and out of gear.
Belt, bearing,tps, wiring, fuel, check valve, breather tube, air filter, etc…
I gave up and took it to a local dealer who was also perplexed and tried everything I had already tried.
on a whim the tech pulled my throttle body and it was caked with oil. He then wiped it all down, sprayed it clean and reinstalled the unit and to his surprise the surging idle stopped.
If you’re at your wits end and have done all of the above, pull your TB and check it for a coat of oil.
my rig has 1400 miles and just under 300 hours. Yes, it averages about 4.5mph.
