Hello All,
First post here looking for some assitance. I have a 2012 Ranger xp800 and recently it begain to throw up the check engine light whenever I was throttling up or powering through some terrain. If I let off the gas, eventually the check engine light would go out. Seems to run fine otherwise. I checked the Code and it shows a 0-3598-4 code which translates (from what I have been able to research) the following "ECU Output Supply Voltage 2 - Voltage too low". I am no mechanic nor do I profess to being even slightly handy when it comes to motors and such, so I am trying to find out what exactly that means... What is ECU output supply voltage 2, and what would cause it to be too low?
Any help would be appreciated.
