Having problems with it keeping it running. Have put 2 new fuel pumps in. It will start run as long as you are giving it gas but as soon as you quit giving it gas it stalls and will not start back up. Wait about 1 hour and it will start again. Any suggestions of what might be the problem.
Check engine light coming on Beck ? you may have an issue with the throttle pedal vane switch. I would pull the connection at the pedal switch and clean it and install di-electric grease before reinstalling to rule that out.
Beck, if you are sure you have 58 psi to the injectors, pull that connector at the pedal and play Mrs Clean.
