We have here a problem with a customers 400 Ranger. will start easy and idle perfect but has no power and misses at high rpm. I personally own a polaris ranger 400, mine has 500 hrs, this problem utv has 300 hrs. Cleaned and checked carb. Switched slide/diaphram/needle with mine. Put in a 135 main jet (had a 150) Switched CDI box with mine. Checked cam lobes for wear, .008 valve clearance, ball in decompressor is sticking out of the cam at rest. Valve timing marks are correct. Mine shows 140 lbs compression with throttle open while cranking. Problem utv has only 80 lbs. Oil in spark plug hole increases his compression to 140 for a couple of tries, then goes back down. All these tests point to bad rings/bore/piston. These old sportsman 500 motors are usually bulletproof especially if oil is changed regular. No air leaks in intake. I guess it is time to pull cylinder off and have a look, Unless you guys that have rode Polaris a long time have run into another problem that we don`t know about. PS He had run with almost a quart too much oil. Could this has caused the damage? Any advice? would be appreciated! Thanks, Robert W
