All,
Received these code yesterday after the check engine light came on. I think these are for the Throttle Body Control from what I can find, but these codes were not directly from a 2013 model year manual. Has anyone got these codes and can you direct me on how to repair this problem.
The Range starts and idles fine, but will not throttle to move.
How to diagnose or what parts do I need to replace?
Thanks in advance!
First try this. Disconnect the wire harness from the throttle pedal and look at the connectors. Look for corrosion or water. Blow out the inside of the connection and apply dielectric grease and reassemble. See if that solves your problem.
No throttle response. If cleaning the pedal connection does not work you have to replace the complete pedal assembly.
