1 - 2 of 2 Posts
The turf mode in my 2014 polaris ranger 800 doesn't engage.
How can you tell if the problem is the Solenoid or internally in the gear case. What should a person look for in the gear case.
With the limited information you gave..... Here are some suggestions.... touch the solenoid while someone engages / disengages turf mode. If you feel it pulse and or hear it, then the solenoid is probably good and the issue is internal. If you don't feel / hear the solenoid, then it could be the solenoid, a contaminated connector, broken wire somewhere between the solenoid and switch or switch. Good luck.
1 - 2 of 2 Posts
